Sir, I replace poltroller in canon 6030,but mechine display an error 002. I know about that error shows fusing temparature. Because my mechine warm up time is not properly. My new plotoroller madeup an aluminium meterial so it cannot heat properly (180 degree celsius). Please help to buy orginal plotoroller. I have ATM card. I will sent money by post. Please sent your address in my mail ID.
123Angela456
SOURCE: Canon IR3300 showing the error code E000602-0003
Nevermind. I researched the error code and fixed the problem. Thanks anyways.
Posted on Jan 03, 2008
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Posted on Apr 03, 2008
Joed911
  • 4338 Answers
SOURCE: canon mp 160 error code e 22
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: canon mp 160 service error 5100 & e2-2
I had same error and tried the reset fix shown elsewhere on this site. It did not fix the problem.
The problem was mechanical as the cartridge cradle was not returning to the far right hand side (viewed from front of printer). I cleaned and lubricated the whole cartridge slide.  Use silicon grease to lubricate the slide.  The ink rest also needs to move to the far right so lubricate that slide channel too.
This can all be achieved by removing just the front panel (lugs only) and then the right hand side panel (4 screws and bottom lug)
Posted on Feb 19, 2009
SOURCE: Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
Posted on Jun 16, 2009
CANON ERR 0001-002 COMEING
error clear on ur mechine .or change ur fusar unit.if ur not undastand plz call me on 09989086587 this number urs ASLAM
Apr 03, 2014 | Canon imageRUNNER 2870 Copier
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
Canon ir 3300 error code E000805-002
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E003-0000
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon GP 405 Mechine mechine has show close the fornt door from ip.please say to how can i repair the ip
this problem due to your composite power supply problem,you can replace 3 burn cap and one fuse(if not mistaken the value is 4amp)
Aug 31, 2011 | Canon Office Equipment & Supplies
Enter ID Number with the Number keys canon 6030
I have a Canon photocopier NP 6030. Problems on my machine, the display panel is written ENTER ID Number ......., How does the solution sir? Listen Read phonetically
Mar 04, 2011 | Canon NP 6035 Copier
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
E-840-002
Hello sir; The error code you display it's means " external heat roller sensor damage , replace it.
Aug 15, 2009 | Canon Office Equipment & Supplies
F-0-0
Heat lamp or thermal fuse is wrongor wrong connectons
Aug 01, 2009 | Canon imageRUNNER 400S Copier
Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Oct 28, 2008 | Canon Office Equipment & Supplies
19 people viewed this question
jasbo
jasbo
