Question about Nelson Sprinkler: Traveling Tractor
How do I get the sprinkler 'T'' HEAD off - Nelson Sprinkler: Traveling Tractor
Hold the plastic nut located just under the "T" with adjustable pliers or wrench and unscrew the "T head" with your hand.
Posted on Apr 15, 2011
Why is replacement sprinkler head leaking?
If water pressure is over minimum recommended rate, your replacement sprinkler head shouldn't leak; it it's leaking probably because it is of a very bad quality. If it's new, return it to the shop where you bought it and clim your warranty right
Sep 13, 2015 | Garden
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Nelson Sprinkler:  Traveling Tractor Logo
41 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
