Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
Installation problems. Ok, I got this router from a friend of mine. Right now, I am trying to get the router connected so I can play XBOX Live. But the problem I have is with the installation CD. I followed the instructions(Connect the Modem to the computer, do not connect the router yet.) and all I get is a message saying that my internet is not connected, even though I can get online and do anything a normal person could do.
  • Anonymous Oct 03, 2008
    got from a buddy
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 15 Answers
the CD is not really necessary for the installation.
Follow these steps :
  • Connect the computer to the router.
  • Open the setup page. Default password is admin.
  • In Setup, click on the subtab, MAC Address Clone.
  • Click Clone. Click Save Settings.
  • Turn OFF the Router and the Modem. Wait for 10 seconds.
  • Turn the Modem ON, wait for 10 secs.
  • Turn the Router ON.
  • Try going Online. You should be ONLINE !!!
  • Click on the Wireless TAB, change the name [SSID].
  • Change the channel to 11-2.462 GHz.
  • If you want to enable wireless security, go for WEP 64 bits.
  • Read this article about Wireless Security.
Hope this helps mate !
All the Best.
Posted on Aug 01, 2008
I use this router to get internet for live on 2 xbox 360s, it works just fine when i connect a single xbox but when i try to connect to the 2nd one has alot of trouble connecting (i do eventually get the...
Could be a few different problems. One is your internet connection speed. If its below 5Ms I would say you are blowing out your bandwidth and it your ISP can't keep up, thus causing a slow connection or even some time-outs. If you are at or above 5M, check what ports you have your connections in. Some hubs are set specifically to take the ISP in a certain port and have it looped through another port. I'd start there.
Oct 04, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Tip
Xbox live NAT
Simple Rules
-if your NAt is strict and cannot connect
try turning your hub off for 30 seconds then turning it back on
if that didnt work.
-try resetting your IP address.
if that didnt work
-take addaptor from xbox to pc out for 30 seconds, then put it back in
if that didnt work
- try opening thies ports
TCP 53
UDP 53
TCP 80
UDP 88
UDP 3074
TCP 3074
Helpfull Info
Sometimes depending on the router brand, it's not possible to open your NAT, this simpily becuase some are not specificly designed for Xbox Live purposes. A good example of this is Belkin routers. These brands are most commonly made for Buissness connection servers. If you are experiencing a STRICT/MODERATE Nat with a Belkin router, the chances are you are going to have to deal with it, but that is not 100% of the time. If you've have attempted several techniques to open your Nat and the changes arnt happening, i'd recommend a 'N' powerd Belkin router, the most majority of these routers work 100% perect for Xbox Live, I myself oned one but changed due to a broadband switch.
How do I change the NAT firewall protection? (Open/Moderate/Strict)
Find your IP address number then type it in on your web browser, this will bring up all your switchable options where several options can be changed to your approval. The NAT firewall is one of these options which can be changed. (like I mentioned before, if you own a Belkin router, the chances are even after changing the fireall level, it will turn back to moderate or strict)
on Feb 17, 2010 | Computers & Internet
Networking problems
Ok you need to set DHCP OFF, go to Start>>RUN>>services.msc then scroll down until you find DHCP Client,. set to OFF & disable it. Reboot. Now login to router and ensure DHCP is ON. That is that problem sorted. So try that.
Cant find IP address
You need to make sure that DHCP is turned on for the router and the the Xbox is set to automaticallly get network settings. If not, then you will need to manually configure the adress and settings. If this is the case, please post back the address of the router and all other devices on your network and we can help you make a suitable choice and get it configured.
Aug 15, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Gigafast ethernet won't let my Xbox connect to live
You might open this ports to the Gigafast Ethernet router :
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
NAT settings
The easiest way to fix this is to replace your router.
Here is a list of routers that are Xbox approved
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
The model you mentioned that you have is not on the approved list from Microsoft.
Here is the problem behind your Xbox connection
http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testnat.htm
Jul 25, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Xbox live
Your router is not LIVE compatible.
Get a Live compatible router.
Feb 24, 2008 | Zonet (zfs3008)
Internet & xbox live sametime Netgear 8-port 10-base-t Ethernet Hub en108
Does the xbox work when connected directly to the internet (not through the hub)? If so, there may be some kind of conflict related to sharing your internet connection between the PC and xbox, and I'd reccommend getting a router instead of a hub.
Feb 20, 2008 | NetGear ProSafe DS104 10-Port Ethernet Hub...
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
245 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
