Question about Toshiba e-Studio 35 Copier
F10 error after getting moved - Toshiba e-Studio 35 Copier
  • 132 Answers
The error is communication error between system cpu and scanner cpu
check the following
(1)check the harness connecting the sys board and the slg board is disconnected or open circuited
(2)check the version of the system rom on the sys board
(3)check the version of the scanner rom version on the slg board
(4)replace the sys board
(5)replace the slg board
but first try doing the latest version of firmware
Posted on Mar 14, 2011
F10 error code on Model # FEFL79GCA Frigidaire Stove
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux range error code f10
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, these codes mean to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 02, 2012 | Electrolux EW30DF65GS Dual Fuel (Electric...
How to get to boot chooer on tne m700 starts
Hi.
  1. Turn on the computer. When the Compaq logo displays, press F10. Or,
  2. During Power On Self Test (POST), and after the memory check completes, press F10 as soon as you see a small white square flashing on the top right corner of the screen.
  3. In the computer setup, use the right arrow to move the selection to the Advanced menu.
  4. Use the down arrow to move the selection down to Boot options, and press Enter. The Boot options menu pops up with four boot order options.
  5. Use the down arrow to move the selection.
  6. Press the left arrow to change the order of Notebook.
  7. Press F10 to accept the change.
  8. Press ESC to jump back File menu, and then move the selection down to "Save changes and exit".
  9. Press Enter. If asked to save changes and exit, press F10.
On some laptops you can change the boot order by tapping the F12 key as the computer starts up.
Regards.
Jul 16, 2011 | Compaq Armada M700 Notebook
How can i fix my cam i have a Fuji fine pix F10....where it reads card error and when i do formatting my cam it does not work then it reads card not initialized what is it means?is my camera hd...
just try removing the memory card and at the side you'll see a tiny switch,slide this in the opsite direction to where it is now and that should work. its a locking system on the memory card, it sometimes gets moved when we remove the card form the camers or put it in a michine to get pics. hope that works.
Mar 18, 2010 | Fuji FinePix F10 Digital Camera
When I put the CD, inside the CD slot, it Say
arm could be stuck
manually move the cd laser back and forth a couple of times then move it to the farthest outward and turn it on.
Oct 11, 2009 | Sony CFD-F10 Radio/Cassette/CD Boombox
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Error F10
There is a topic alryde about the F10 error
You will get your answer here
http://www.fixya.com/support/t1461650-wf840_f10_error_code_get_worse
Good luck to you!
Please take a moment and rate my answer
Nic
Feb 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Alt f10 will not work
I do not know what type of device you have nor do I know the O/S you are using. What function are you trying to Accomplish by this move? I can not think of anything that Alt+F10 does. Are you sure you don't mean The "FN" key and F10? Please try the FN key and F10 to see if you get the result you are looking for.
Feb 03, 2009 | Computers & Internet
Fuji Finepix F10 won't mount onto Mac mini OS X
Best use Memory Card Readers, F10 is USB 1.1 so moving data is quite slow specially if you take 6MP photos. Just get a XD card reader whihc is USB 2.0
Jan 01, 2009 | Fuji FinePix F10 Digital Camera
101 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
