Question about Gem Sound GemSound PLL-32 Microphone
How do i setup my microphone so it works with the pll-32
I cant get any sound out of my microphone. i know nothing about channels, frequ, or anything else. help!
  • 31 Answers
What kind of mic and what are you running it into ?
Posted on Aug 07, 2008
I cant pick up any channels on my 32'' Emerson hdtv with my channell scan
Did you select antenna in the setup menu?
If you did and still can't receive anything you may not be receiving signals strong enough. Read the setup instructions in the manual. link below.
LC320EM9 EMERSON LCD TELEVISION Manual
Sep 09, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Cobra 1000 will not receive or transmit.
Sounds like a problem with the VCO / PLL Circuit since nothing happens in RX or TX. Check to make sure you have the correct supply voltages to start with and also check to see if you have 10.240Mhz. Use the service manual and go through the PLL/VCO alignment section. If anything is missing then you at least know where to look.
Apr 30, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
I cant hear nothings on my computer theirs no sound it says theirs is no speakers or headphones plugged in and wel they are plugged in (compaq presario SR5202HM) windows 7 ultimate 32 bit.
are you using a sound Card the presario SR5202HM has this sound setup
Sound/Audio Integrated Realtek ALC888 Audio
  • Audio CODEC: Realtek ALC888
  • High Definition 6 channel audio
make sure that this sound driver is up to date
here is the plugs
4 - Audio: Line In (light blue) 5 - Audio: Line Out (lime) 6 - Audio: Microphone (pink) make sure you have the headphones plugged into the Lime colored plug
if this doesn't work i have some more idea's let me know.
Jan 23, 2011 | Compaq Audio card Sound Card
Some channels have no sound, other channels are ok, one channel sound goes in and out....what do I check for?
Problem :
some channels have no sound.
Solution:
Theres nothing wrong with your TV, is a misconfiguration of your Cable / Satellite box.
Check in the Setup of your Box the language option and select "Channel default"
hope to help you.
Please Rate my solution
Aug 18, 2010 | Sylvania LC320SLX 32 in. LCD TV
I cant seem to be able to record anything on my microphone it is not picking up any sound. Why is that?
your CAD mic is a condensor mic and needs phantom power. If you don't have that it won't work. If you need phantom power you can get it from a small mixer. We here at proline carry some small multi channel mixers that have phantom power in them. call 215-736-8055
Jan 14, 2010 | CAD Microphones GXL2400 Professional...
Bought an MXL V88 Mic and i hear no sound ,not working
go to control panel> hardware and sound> sound; click recording tab, select USB Audio Codec, select Properties, click Advanced tab, select 2 Channel 16 bit 44100Hz and then hit apply. You have to make sure you have the 2 channel option selected. otherwise the computer just recognizes one channel and assigns it for playback. HTH
Apr 09, 2009 | Audio Players & Recorders
I want to know how to convert my superstar121
3 Bands (LOW - MID - HIGH) 25.515 - 27.855 MHz.
Export Frequency Conversion
1. Remove the top cover from the unit and locate the PLL chip (MC145106P). Unsolder the short jumper wire running from the +8.2vdc source to pin 9 of the PLL chip. 2. 2. Resolder the three pins of the PLL chip, Pins 10, 11, and 12, being carefull not to short them together. Note: The Super Star 140 Microphone wiring is the same as all Midland Radios.
Mar 12, 2009 | Superstar SS-121 120-Channels Base CB...
Sound setting
do a set up and turn off sap in the audio setup.auto program again
Oct 28, 2007 | RCA 32F531T 32" TV
Gem Sound GemSound PLL-32 Microphone Logo
83 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
