Question about Swintec 7040 Typewriter
Swintec 2600 Electric Typewriter
I just got this used typewriter.
How do I reset the margins?
How do I set the tabs?
Thanks for your help.
Diane
djoseph121@yahoo.com
    Sergeant:
  • 329 Answers
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Posted on Aug 01, 2008
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How do you clear the right margin
Go to the R. margin, press but don't hold the MAR REL key, space to desired location press R. margin key.
DickyO
Aug 05, 2014 | Swintec 2600 Electric Typewriter
How do you release right margin
Push the Mar Rel key, then you should be able to space or type through the right margin.
Need user manual for swintec 2600
You can purchase one here... http://www.swintec.com/typewriter-manuals/111-swintec-2600-manual.html
Jul 16, 2014 | Swintec 2600 Electric Typewriter
Carrier stops in the middle and moves only when press TAB twice
Hold down the margin release key and turn on, machine will print test till turn off. Resets the TW, depress the left and right margin keys together will reset the margins to 10 and 75.
Feb 02, 2014 | Swintec 8014-s Electric Typewriter W/...
How to clear tabs on Swintec 2600 typewriter
To clear all the tabs tab allthe way to the right, hold tab clear and press return. If you are trying to clear margins go to the margin, press but don't hold the mar rel key, space or backspace to desired location, press L. or R. mar key.
DickyO
Mar 28, 2012 | Swintec Office Equipment & Supplies
How do i release the tab position?
At each tab stop, press the "tab release" button. Then tab to the next tab position and do the same. OR
You can put the machine in "service mode" which will erase all tab stops and reset your margins to their default positions. Easily done by turning the typewriter OFF. Then while off, press and hold "mar rel" (margin release) key on upper left side of keyboard. While holding it down and keeping it down, turn the typewriter ON. Then take your finger off the Margin Release key. The typewriter will start typing all by itself. Turn the typewriter off, then on. That will reset everything. All tab stops will be erased and margins reset to their defaults.
Jan 04, 2012 | Swintec 7040 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
Margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 06, 2009 | Swintec Office Equipment & Supplies
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
1,008 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
