Question about Singer CE-100 Futura Computerized Sewing Machine
I have a furtura ce-100 version 1.0.02 trying to down load disc to my HP note book w/windows 7
    Novelist:
  • 233 Answers
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Class\(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then Windows\System 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Posted on Apr 20, 2011
Have a c-150 furtura ...i'm getting a bad stitch on the bobbin thread with both reg and embroidery stitching how do i fix this been in repair shop 3 times comes back with still bad stitch they use...
ANOTHER THING IS TO CHECK THE TENSION OF THE BOBBIN THREAD. MAKE SURE THE THREAD YOU ARE USING IS GOOD THREAD THAT DOESN'T PULL THE COTTON UP AND CAUSE A PUFF BALL ON THE NEEDLE. CHECK THE WAY YOU ARE LOADING THE TOP THREAD. ALWAYS DO THIS WHILE THE FOOT IS UP SO THAT YOU CAN CONTINUOUSLY GIVE TUGS THROUGH EACH OF THE GUIDES. THIS HAS TO BE LITTLE TENSION WITH NO SNAGS.
Apr 23, 2014 | Singer CE-100 Futura Computerized Sewing...
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
Machine will not work on windows 7 64 bit computer will not load singer discs bought new computer old system was X P
First, there's a Windows 7 update available atwww.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350,etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALLFutura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set ofinstructions athttp://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that willallow you to run the software under XP on your Windows 7 machine. This is a bitmore complicated a solution, but if you follow the instructions carefully, youshould be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Apr 26, 2011 | Singer CE-100 Futura Computerized Sewing...
No drivers will load for windows 7
There's a patch available at www.Futura-support.com for Windows 7.
Sep 17, 2010 | Singer CE-100 Futura Computerized Sewing...
Unable to link windows 7 with sewing machine . We are trying to use our laptop which is a Windows 7 and the Furtura sewing machine, but the laptop won't accept the disk. is there another driver we can...
Unfortunately, there is no other disk. There is a patch available at www.Futura-support.com to try. If the laptop is actually spitting the disk out rather than saying it can't read it, your disk may be bad, not just scratched. You may need a replacement. See if it can be read by another PC.
Jul 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer CE-150 Futura can not locate driver software?
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
http://www.futura-support.com/downloads/ce150.html
Feb 20, 2010 | Singer CE-100 Futura Computerized Sewing...
My wife has a Singer C100 embroidery machine and I purchased a new laptop (windows 7) for her. When I tried to load on her ''Futura'' software it will not load. It went so far and then stopped. The files...
I've read about quite a few people having issues with Vista, so Windows 7 may not be supported yet, you may want to try calling singer or windows or both to see if there is some kind of patch or update
Jan 05, 2010 | Singer CE-100 Futura Computerized Sewing...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Trnsmitting problems I cant transmitt to my machine and it is now getting frustrating.
I have the solution! After calling 1-8004SINGER.
When this happens,
turn off emb. machine
detach hoop
exit out of futura program back to the windows screen
Then, turn on emb. machine
Reattach hoop
Open Furtura program
Select design
Select transmit button
and this should work. You have to this in the exact same order each time.
Mar 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
69 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
