Question about Lexmark C534N Printer
Paper keeps jamming in fuser, inner door and tray, can firmware upgrade fix this, its a c534dn
  • Lexmark Master
  • 1,915 Answers
A paper jam as you describe could be caused by the following:
The fuser is defective and causing the jam.
The tray has a problem and it is not picking up the paper properly which causes a timing problem that results in a jam.
A bad sensor is stopping the printer from being able to tell if the right size paper is being fed through the printer.
Try printing from the manual tray to eliminate a problem with the standard paper tray. If it still jams it is very possible that your fuser has an issue and will require replacement. Are there any errors in the error log?
Posted on Mar 15, 2011
  • villarr Apr 08, 2011
    Hello, I have the same troube with my two printers Xerox Phaser 3110. There are no errors in the error log, and I changed tray and the problem remains. Please help me to define what do I need to replace, the fuse or the sensor?
Hp p4015n keeps jamming
Jamming where? Is paper crumpled up in printer or does printer just stop. Likely the rollers in tray 2 are worn. Try printing from the MP tray, if that works then printer is ok and it will be the feed/sep rollers in tray 2. It is also very important on this model to ensure that you have current firmware installed as older versions of firmware have a bug that will wreck the fuser.
Apr 18, 2014 | HP LaserJet P4015N Printer
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
Paper Jam 13.20 on HP 4015
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on or when the top door was closed.
Action:
1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
4. Replace any defective sensors or flags
Hope this helps. Please keep us updated and remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Jan 06, 2009 | Sharp AL-1642CS Copier
Printer now not printing, as it says there is a paper jam
it sounds as though your pick up rollers are worn. when the oprinter can not pick the paper from the selected tray (tray 2 in your case) then it shows up as a jam. to sort this you will need:
One of these: RM1-0036-020: PAPER PICK-UP ROLLER ***'Y
Two of these: RM1-0037-020: PAPER FEED ROLLER ***'Y
Hope This Helps
Pete
Oct 30, 2008 | HP LaserJet 4250n Printer
Lexmark C534N Printer Logo
596 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
