Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
It has power, and runs, but NO heat - Maytag MDE9700AYW Neptune 174 Electric Dryer
    Problem Solver:
  • 30 Answers
Resistance is broken
Posted on Mar 14, 2011
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
Jul 15, 2015 | Kenmore Elite Microwave, Model...
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
DRYER NOT HEATING UP
Matthew Campbell,
I understand that your Frigidaire electric dryer will run but is not heating up. What I would suggest would be to give the appliance a hard reset.
You can do this by either unplugging it or cutting the power at the Circuit Breaker for 3-5 minutes. After resetting it for the 3-5 minutes, bring power back to the dryer. Run any cycle and see if you are getting heat or not.
If you are not getting any heat to the appliance, it could be either something to do with the heating element or possibly the control board itself. The other possibility would be the wiring going between the heating element and the control board.
I would recommend contacting a local authorized technician to determine what exactly is the root of the dryer not heating.
-Best Regards-
Jan 14, 2014 | Frigidaire Electric Dryer
BLOWER MOTER RUNS BUT NO HEAT JUST COLD AIR
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 10, 2011 | Heating & Cooling
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Whirlpool Dryers
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Will not run
check your recepticle .most dryers will run on half power but willnot heat. if your recepticle is bad ` it may have lost all power.
Feb 18, 2008 | Whirlpool LER4634J Electric Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
