Question about Kyocera Mita KM-2530 Laser Printer
My Kyocera KM-c2230 said: "the following units need to be replaced soon - Paper Dust Remover/Ozone Filter and Image Transfer Roller Unit." I replaced both units and still have the message! I have tried shutting the copier off, of course...I have tried removing them and re-installing them...all to no avail. Please advise...
4 Suggested Answers
admin734
  • 268 Answers
SOURCE: Service manual for a Kyocera KM-C2230 Copier?
Here are the manuals associated with that copier: http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13007&pcat=10565&rcid=10009&rscid=10028
Hope that helps you out!
Posted on Oct 02, 2008
  • 15 Answers
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Posted on Jan 15, 2010
Bizhubman
  • 108 Answers
SOURCE: Where do I find the Paper Dust Remover/Ozone
I believe the filter is located on the right or left side. The "Transfer Roller Unit" is the foam roller inside the right door.
Posted on May 17, 2010
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
How do I get into menu to reset consumables ?? Like ozone filter, paper dust filter, transfer roller unit
Press "utility/counter" then "details" then stop, 0, 0, stop, 0, 1
This gets you into service mode.
Then press Counter the Life.
Be very careful not to mess with much in the service mode tho.
Good Luck andThank You for using Fixya
Nov 09, 2010 | Konica Minolta bizhub C351 All-In-One...
Where do I find the Paper Dust Remover/Ozone Filter and the Transfer Roller Unit?
Apr 07, 2010 | Konica Minolta bizhub C351 All-In-One...
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Feb 04, 2010 | Kyocera FS-4000DN Laser Printer
I have a Konica Minolta Bizhub C350 which is now indicating that it needs to have the image transfer roller unite and paper dust/ozone filter replaced. Where are these located in the machine and is it...
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Laser printer not printing properly left side of page is very light, right side is normal, have tried redistributing toner and changing toner cartridge
Since you have changed the tone cartridges ...and it still does the same....
the next step is to check the transfer belt..transfer roller(this when hit by laser light stores the image and runs on the powder ink..the parts that have been created by the laser on the transfer belt is where the powder sticks)......remover the transfer belt roller and check to verify that its not worn out..its in the form of plastic paper more like Teflon.....view to see that it doesn't have severe markings...if its marked you will need to change the transfer belt to
If this doesn't fix the problem than you will need to change the laser scanner unit....
so basically its your cartridge...that provides color powder dust for image....
transferbelt...that transfers the image to the paper with the image being created by the laser scanner and the cartridge providing color
the last process is fussing ...heat is used to make stick the powder to the paper..and is done by the fusser unit...
as for your case the image is not either created by the scanner itself in the right manner..or the image is not properly created coz the transfer belt is worn out....
I suggest you replace the transfer belt next.
cheers!
Nov 10, 2008 | Office Equipment & Supplies
Consumable replacement message
You need to go into service mode to reset these parts. Start by hitting the "Utility" button on the control panel. Then select "Meter Count" from the menu. Next hit "Details". Then you need to hit the following buttons in this order, STOP,0,0,STOP,0,1. This will bring you into the service mode on this machine. From there you should select "Counter". From the Counter menu select "Special parts counter". Highlight the parts you replaced and hit the "C" on the control panel to clear the counter. This process should be done for any parts that you replace and will prevent the message from popping up.
May 11, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Kyocera Mita KM-2530 Laser Printer Logo
125 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
