Question about Bissell Vacuums
Our Bissell Pro heat Select Pet 2 x was given to us...no manual. (about 3 yrs old) The brushes do not rotate and water/shampoo does not come out when you hit the switch. We have looked it over and cannot find anything wrong. any suggestions?
  • 48 Answers
SOURCE: Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Posted on Nov 18, 2007
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
earl5445
SOURCE: Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Posted on May 06, 2009
  • 29 Answers
SOURCE: I have a bissell pro heat water wont come out
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
SOURCE: Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Posted on Jul 12, 2009
My Bissell pro heat pet 2x model 9200 does not allow the shampoo to mix with the water. Something must be clogged, and I don't know how to unclog
The 2X is designed with 5 solenoids. I am not allowed to tell you that it's a flaw in the design, but I will say that is the only machine on the market that our store refuses to work on. Buy a Hoover F5914-900 machine and end your pain.
Jun 08, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell pro heat 2xthe brushes will not spray the shampoo.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tryrt
May 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pet Eraser brush only rotating on the bare floor setting, when on the pet setting, it won't rotate. What is the problem? Thanks.
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
Jan 03, 2010 | Bissell Upright Vacuum - The Pet Hair...
Bissell pet hair eraser-the brush is not rotating but the suction is working on the removable parts
That means that you need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Jan 01, 2010 | Vacuums
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Open Questions:
Vacuums Logo
169 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
