Question about Inter-Tel GLX-Plus Corded Phone
My inter-tel GLX Plus volume is too loud. Whenever I adjust the volume for the ringer it just goes back to what it was! When the phone rings it's blasting in my ears and I'm getting tired of these ear aches!
3 Suggested Answers
consultel1
  • 860 Answers
SOURCE: Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Posted on Dec 22, 2009
  • 25 Answers
SOURCE: I have the Inter-tel ECX 1000 phone system. I have
you can contact the mobile service provider....
Posted on Sep 20, 2011
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
When I place a call on hold, after 1 minute, it rings back to my phone. How do I stop that ring back?
You will probably need to get with your IT people to adjust the time, it is set so you do not forget about the person on hold...
Jul 29, 2015 | Inter-Tel Intertel GLX-Plus Executive...
How do I turn off the ringer on an Inter-tel 662.3600?
Do Not Disturb --
While in do not disturb mode: You do not receive intercom calls, Transfered calls or pages, You do not receive direct ring in calls, Queue callbacks , and recalls.
* While on-hook, Press DND to turn on or to cancel. Key lights up when on and goes off when canceled. http://pdf.textfiles.com/manuals/TELECOM-F-R/Inter-Tel%20GX%20Keyset%202.pdf
Sep 29, 2014 | Lands Phones
Phone will not ring
you check your setting problem otherwise you read the phone catalogue.
Mar 26, 2013 | Inter-Tel Intertel 6123300 GLX Executive...
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Inter-Tel GLX-Plus Corded Phone Logo
101 people viewed this question
Top Inter-Tel Lands Phones Experts
David Burbee
David Burbee
ray gallant
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
