Question about Toshiba 65H84 65" Rear Projection HDTV
Hi, My friend has a Toshiba 65h84 Rear projection tv that has bad picture. when turned on it shows some snow effect but pink instead of white. when we connect the cable you can see distorted video on the background.
  • 84 Answers
Chances are you have a defective hyper module. The symptom with this problem is called piecrusting and appears as a squiggly and distorted picture, usually worse at the top. It may dissipate after 20 to 30 minutes as well. This module has been out of production for a few years but some regional companies will rebuild it for around $125.
Bill W
integrityhomeworx.com
Posted on Mar 14, 2011
The unit will not turn on. A red light blinds and that it. No picture and no sound
I have the same problem on the same tv. If you have fixed it by now please inform me how, I would really appreciate it. And vice versa if I get mine fixed.
Aug 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
The picture on my Toshiba 65H84 - 65 Inch Theaterwide HD Projection Television is going dark. Is there a bulb that I can replace? If so, how?
This model 65H84 is a rear projection type with three picture tubes. And if I am not mistaken is around 10 years old. So, if it is at least 10 years old then the picture tubes are getting weak and burned out, therefore not producing a bright enough picture. Typical with rear projection with age on them.
Jun 28, 2011 | Televison & Video
Toshiba 36A60 does not show signal on main antenna/signal source. Antenna 1 went out first. Video 1 and video 2 seem to be slowly losing picture. There is only snow and static instead of a picture on Ant...
The tuner module is bad and would have to be replaced, the other concern is video 1 and 2 are now becoming snowy, at this point I would suggest replacing the tv set because there are two separate issues and the cost to repair in my view would not be cost effective, cheaper in the long run to buy new tv.
Jan 25, 2011 | Toshiba 36A60 36" TV
HDMI Cable yanked out while tv was on!!
Bryan, it looks like you had damaged the HDMI interface chip when the connecter bent. The bending created a short with two of the contacts in the chip.
I had a similar situation where the HDMI cable from the cable box was yanked off without any visible damage. However, the same cable work with the dvd player. In my case the interface in the cable box was damaged. It is not worth the trouble to repair the board.
Aug 23, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Problem with toshiba 65H84
Good Day, mowattearl;
The most common with this TOS TV is the failure of the convergence IC's, but rebooting, resetting first, unplug TV from wall for 3-5 minutes then plug back into wall. The "conv" IC's are STK's, large black devices mounted to a large heat sink on the verticle.
Good luck, big IRISH.
Jul 24, 2008 | Toshiba 65H84 65" Rear Projection HDTV
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 65H84 65" Rear Projection HDTV Logo
378 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
