Question about RCA 27F530T 27" TV
My RCA Model 27F530T is turning on and off after being on for only a few minutes. When it turns back on, its ususally on a different channel. I read the manual, the only thing thats comes close to sounding like this is a high or low voltage in my apartment. What else could it be, my voltage is fine.
    Top Expert:
  • RCA Master
  • 74,251 Answers
Hello
The fault you reports indicates some voltage problems inside it itsef. Check first, for any loose plug in point on your wall power socket. if it all found ok, there will be some loose soldering contacts inside your TVs power inverter section. This is a common fault for all TVs including plasma ones. Usually, loose soldering points are very difficult to locate, as they will be microscopic. The only way to overcome this, is to resolder all the suspected points, especially solder terminals of high wattage resistor, and the regulator device. Resolder most of that points by applying a little more solder, without shorting the adjecent solder points. you must have a concept of soldering to do this job. some knowledge in electronics also is necessary. The most important are confidence and patience. If you have these, do it after open your Tv. You will get sucess. OK.
Posted on Mar 14, 2011
Can't turn on T.V. @ sign comes on.... next to Channel #03
front panel lock has to be unlocked with original remote....try mrremote.com punch in model# ..........good success...........Meder's tv service
Feb 21, 2009 | RCA 27F530T 27" TV
Black rectangle covers perhaps 90 percent of the screen
Closed caption has to be turned off.http://support.ttetech.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf link to owner's manual........good success, Meder's Tv Service
Jan 22, 2009 | RCA 27F530T 27" TV
No sound
turn close captions off (CC)
Jul 03, 2008 | RCA 27F530T 27" TV
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
Programming code for rca 27f530t tv
RCA TV Codes.
11447, 10047, 10019, 10679, 11247, 11547, 10090, 11147, 11047, 11347, 10018
From http://www.satex.com/directv/tv_codes.html
Jan 06, 2008 | RCA 27F530T 27" TV
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
Getting the deleated channels back on my TV
it sound to be an eprom failure and thats nothing that you can do take the tv to a tech and pray for a cheap repair... good luck
Aug 06, 2006 | RCA 27F530T 27" TV
Televison problem
Have you had any storms come around recently? This sounds like the EEPROM IC is corrupt and probably needs to be changed. If you know how to solder maybe you can change it your self. If your not good at soldering then you can have a pro assist you with this repair Good Luck
Jul 24, 2006 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
