Question about Ovens
I Am an Electrician, and a customer of mine is buying a Cata efm60ss oven, I Need to know the KW rating so I Know whether to put in a seperate supply or if can run off a 13amp plug top Thanks.
  • jem_elec Mar 14, 2011
    Thanks Apptech 79, I saw somewhere that it was 2.38kw but wanted to check
    New Friend:
If you are a electrian then you know in your IEE 16th or 17th exam BS7671 ,that a main cooker is a fixed appliance and needs its own 32A main feed. Do not run a main cooker of a plug it is dangerous, Seek a qualified and experienced electrian to install a main kichen cooker.
Posted on Mar 02, 2015
    Sergeant:
    Novelist:
  • 196 Answers
From what i can gather it is 2.4KW so 13 amp would be ok
Posted on Mar 14, 2011
What power supply does a efm60ss cata oven need
If in Europe then it will be 230v. I see online that it is rated 13A.
Dec 09, 2016 | Ovens
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
Hi.
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Jun 22, 2011 | Ovens
Hi i have purchased a milano 60cm fan forced wall oven. the electrician putting in a new circuit needs to know how many amps 15A or 20A.. Thanks Tony
Sorry but if he is an electrician he should know what to do! The new wall oven will have a sticker on it with the kilowatt rating. The kilowatt rating is used to calculate the current it will draw. This calculation is dependant on your voltage supply. Once this is worked out it will determine circuit size. If your electrician can't work this out you need to find a new electrician.
Mar 01, 2011 | Ovens
I need the user instructions for a cata oven
i have a cata oven but the paint has come off and dont know what setting is for what
Nov 27, 2010 | Ovens
Manual cata efm60ss oven
Ive had a cata efm6022 for 13 months, and its one thats used 3 times a week. On christmas day the blinking thing stopped working. Theres electric getrting to it cause the fan is working and the light. But its just blowing cold air. Any ideas would be appreciated.
Sep 24, 2010 | Ovens
I am trying to find the KW rating of the HBL3550UC so that I can rough in the electric. They couldn't even tell me that info at the store. Thank you.
hi could not find kw rating but found it needs 30- 40 amp supply. it will tell you the kw on therating plate located around the door area.
Jul 23, 2010 | Bosch 300 Series HBL3550UC 30" Double...
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
516 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
