Question about Toshiba e-Studio 350 Copier
I have a e-studio 352 psl 3 copier. i installed driver 352/452 pcl 6. but eror when print pdf file from pc. i need 352 psl3 printer driver software
  • 29 Answers
You driver is not working order, you could download in the http://mba.toshiba.com/support/index.jsp, you only have to write or select the model and download it.
Good luck.
Posted on Mar 22, 2011
I have a HP color laser printer (HP2605) coneted to a router via the USB port and installed a Universal HP printer driver PS (v5.2). But in word i cant print anny document with pictures (text only is no...
Postscript drivers have very limited features in terms of print drivers. If there are other available, you should use those instead. PCL 6 or 5E would be the best for both Mac and PC and should be available for download from the HP website.
Mar 01, 2011 | HP LaserJet 2605DTN Color Printer
Won't print pdf files
We had this also. Switched from Post Script Driver to PCL and PDF files printed.
Aug 20, 2010 | Toshiba e-Studio 350 Copier
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
I have a toshiba e-studio 352 as a network printer on a win 7 system, I am able to scan from the printer to the pc, but when I try to print on the printer nothing happens. I did ping the printer and the...
try following
- download the newest printer driver from http://www.copiers.toshiba.com/support/index.jsp
- uninstall current driver
- delete port if it is still present
- restart the machine
- start setup (choose XPS printer driver and PCL printer driver)
- setup should offer the machine with IP automatically, if not enter IP manually
- print test page
- it should be working if not let me know, write in comment what happened
regards
Feb 24, 2010 | Toshiba e-STUDIO166 Printer
Pdf file too large: 1-2 pages about 1 MG.
Try and print the document 1 page at a time, upgrade the memory in the printer if you can, and most importantly; make sure that this is not a false error because the PDF requires postscript fonts to be installed you don't have installed on your printer. You can do this as follows.
Their are 3 standards for postscript, go to the manufacturers website and download the newest version of the postscript driver, not PCL. Many printers go nuts if running on an installed PCL driver and asked to print a PDF. If all else fails, this typically gives a lot of false errors.
Nov 08, 2009 | Brother MFC-8860DN All-In-One Laser...
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
Pcl 5e driver for hp laserjet 1320
Make sure you can view filenames with the trailing dot and 3 letters so you can see the type of file. (Use tools menu, folder options, view, uncheck "hide extensions for known types") Doubleclick on the downloaded file and note where it is unzipping to (c:\lj something or other). Open that folder. Right click on the file ending in .inf and choose "install" in the menu that pops up. If that fails, open the control panel, choose Printers & faxes, rightclick on the HP printer, and choose "properties". Look for the "update driver" button, probably under "advanced". Help it choose that .inf file.
Sep 10, 2007 | HP LaserJet 1320 Printer
Toshiba e-Studio 350 Copier Logo
417 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
