Question about Dell Inspiron Mini 10 Notebook
When i try to connect my dell mini 10 to an external monitor first the external monitor show the screen for a second then it goes blank and the display is switched back to the laptop monitor
  • 28 Answers
Have you tried the following:
Hold the FN key down and hit the CRT/LCD button?
Posted on Mar 14, 2011
Dell Inspiron MINI 1012 Laptop Screen 10.1 LED flickers
soldbyajt,
It sounds as though the video card has gone bad in your system. There are a couple of things to try to eliminate the lcd.
If the LCD on the system shows no display or has other problems, here are some basic steps to take:
  1. If the LCD is not displaying any video, connect an external monitor to eliminate a no-POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  2. Connect an external monitor when possible for all LCD-related problems to help eliminate a possible software or video card problem.
  3. If the LCD has lines on the screen, check the system during POST as well as system setup to determine if the lines are present in all modes of operation.
    If you cannot get any video by connecting an external monitor then your motherboard will need to be replaced. The reason for the motherboard replacement is because your video card is soldered onto the motherboard.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
Jan 11, 2013 | Dell Inspiron Mini 1012 Netbook
I want to factory reset a mini 10 but screen is broke(i am using t.v) im afraid to start the process and then not be able to see anything after
Yes that could be horrid. Try setting the tv as your only screen. If you go to l settings Navigate to the "Start" menu, and click it once to open it. Select "Control Panel." Click "Adjust Screen Resolution" under "Appearance and Personalization." Click the drop-down arrow next to "Multiple Displays" in the window that opens. Select "Show Desktop Only On 2." Windows will disable the Mini 10 display and use the external monitor as the primary screen Read more: How to Run an External Monitor on a Dell Inspiron Mini 9 ' eHow.com http://www.ehow.com/how_6821296_run-dell-inspiron-mini-9.html#ixzz1hFvetaud
Nov 25, 2011 | Dell Inspiron Mini 10 Notebook
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
The laptop screen will not come on. it shows the dell powerup logo then goes black. The monitor lights are on so it is getting power but it isn't showing anything on the screen
If it's a Mini 1012 there is a VGA (15 pin) connector on the left side of the laptop. You can try to connect an external monitor to see if you get a display. If you do, then your LCD display has a problem and needs to be replaced. If you have a Mini 1010 there is an HDMI jack on the right side of the laptop where you can connect an external monitor.
Jan 26, 2011 | Dell Inspiron Mini 10 Notebook
I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Mar 10, 2010 | HP Pavilion ze2000 Notebook
Laptop to TV Connection
Check if you are sending the signal to the external monitor. On my laptop with Windows 7, I can right click on an open section of the desktop and choose Graphics Properties. In this window, I can choose to send the display to the laptop's internal monitor, the external monitor or both.
Pressing Crtl-Alt-F1 will force the video onto the external monitor on the fly (Crtl-Alt-F3 goes back to the laptop's screen).
When I have added a second monitor to a desktop, I needed to reboot and allow new hardware to be found before the related Screen Resolution (right click on the desktop again) let me find the second monitor and choose if this was a duplicate or extended screen.
I hope this helps.
Mar 08, 2010 | Dell Inspiron 6400 Notebook
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell Inspiron Mini 10 Notebook Logo
246 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
