Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Air from freezer and refrigerator is not cold. Now motor/fan is not kicking on. I know it is hard to say without seeing it but is it worth fixing.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Freezer side working but fridge side is not?
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop. What you have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $60-$100 for the fan motor then labor on top of that. If you have a model number I could look it up for you :)
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer gets cold, upper refrigerator does not. Looks like there is an opening for cold air to come into the refrigerator, it isn't blocked. Air just isn't rising from freezer to fridge.
you have bad fan motor,located behind freezer wall,accessible from the front inside freezer,lots of disassembly required-awkward repair,but worth it
Mar 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerator just showed problem code Er ff. Can I open the fan motors to defost without making matters worst
I would interpret "ff" to mean freezer fan. I would assume that the code means that the freezer fan is not turning. When this happens, cold air does not get distributed well inside the freezer and very little cold air is sent to the refrigerator section.
The fan is likely behind an access plate in the freezer section. Remove the screws and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 15, 2009 | Refrigerators
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator section does not cool; freezer works fine
Check the settings first. They should be set to the factory settings in most cases. Otherwise check the back of your freezer to see if it is icing up, you may need to remove the back panel to see the ice. If this is the case the ice may be preventing the fan to circulate the cold air into the freezer and you will need a new defrost timer. However if there is no ice and the fan never kicks on you may need a new fan motor.
Jul 05, 2009 | Kenmore 73752 / 73754 Top Freezer...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Troubleshoot fridge repair
Your description is a little hard to understand, but sounds like an evaporator fan is not working. Its the one inside the freezer half. Its not visible, but there are vents that air can be felt by if its working. Or remove the panel covering it to see.
Jan 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator wont circulate cold air
Couldnt find anything on you model #... Might try jumping out the door switch... some refrigerators the door switch will stop the fan motor.. if you have a wireing diagram post on here.. some refrig. have one tugged under front .. some hard to find if any
Aug 30, 2007 | Amana ARS9266BS Side by Side Refrigerator
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
