Question about Craftsman Saws
Motor will not run on scroll saw #315.216090...electric power to saw light.
    Problem Solver:
  • 13 Answers
If the tension is to great on the tension arm the motor can not overcome the tension to start. Disconnect the tension arm from the blade and see if the motor will run. If so the tension was to great. If not test the wiring going into the motor to make sure there are no breaks.
Posted on Mar 16, 2011
Bosch rs5 brushes how to replace them
most small wattage electrical motor brushes are held in by a plastic plug with a screw driver slot in the face in the side of the motor casing
with the power disconnected from the wall
remove those plugs and pull out the spring and brush
insert the new brushes
Jun 26, 2017 | Bosch Saws
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Motor kicks off and has to be reset after just a few seconds, even with a very light load. The saw is unusable.
I would check the power outlet, Make sure you have sufficient amps for the unit. After that I would try and just run the tool under no load. If you still have a problem then I would have to think the motor or related electrical is your problem.
Sep 11, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
My scroll saw will not come on. There is power to
The motor is probably fine. Try taking the case apart and check for a loose connection to the motor.
Nov 25, 2009 | Skil 5.0 Amp Variable Speed...
Saw blade broke. motor won't run after changing blade. reset wasn't tripped. lite still works so its not in the power cord.help! this is a craftsman 16 in. variable speed scroll saw not used very much....
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Jul 17, 2009 | Craftsman 16" Variable Speed Scroll Saw
Saws Logo
89 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
