Question about Panasonic Computers & Internet
How do I add music to a video using Panasonic HD writer AE3.0 software.
SOURCE: Error reading uploaded video using HD Writer
Sorry for my English.
Try split the scene using camcoder, in which there are no thumbnails when playing in HD Writer
Posted on Jan 03, 2010
timili
  • 82 Answers
SOURCE: I purchased a Panasonic HDC HS 20 high definition
you can try doremisoft.net there are many video software which are easy to use and fast.
http://www.doremisoft.net/
Posted on Mar 16, 2010
alanbahia
SOURCE: HD Writer AE 1.0 won't import my videos to laptop
Hi There, few things to follow:
1. Install an update from Panasonic website at www.panasonic.net (This is a pack of 4 files you need to download 1 by 1) 2. Plug your camcorder to the back usb and not in the front port. 3. Disable your Resident Shield on your anti-virus.
Done!
Posted on Apr 19, 2010
SOURCE: I have the videocam suite 2.0 for my new panasonic , add music?
NO, you need to re-master the Video, and then save as say in an MPEG4 format, then using a Movie making software, edit the "Movie" and "Add" the sound tracks etc. You could either save it to a Memory stick, or stream it to the PC, via, link, and save it. Then do as related above.
Posted on Apr 28, 2010
Keynan
  • 977 Answers
SOURCE: Hallo, I have a Panasonic HDC-SD600
Hi Nikolas!
There are 2 models of this camcorder: NTSC or PAL, so there's no setting within the camera to change the rcording TV system (PAL or NTSC).
Apparently, the TV system used by your camcorder is different that what you've selected while installing HD Writer software.
I can't find any detailed manual for HD Writer on the web, to direct you on how to change the preferred video format, but by uninstalling and reinstalling the software, you can choose another country which uses the your camcorder's video format (for example: USA- for NTSC; Australia- for PAL; etc.).
By the way, I've answered a exactly similar question to yours few days ago and it seems like my solution worked! You can read more about it here.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good uck and best regards,
Pelu.
Posted on Feb 13, 2011
I have a Panasonic HMTA1 Camcorder and it installed HD Writer PE 1.0 onto my computer. I am able to unload all my videos and photos from the camcorder to my computer, but now my hard drive is getting full...
The files are just MP4 video, or JPG, images. There's no 'export' needed.
Not sure about 'cleanly', I used copy/paste. Please explain.
As far as the software goes, you can obtain the full version software from Panasonic, but I see no reason why you would want to.
Aug 15, 2011 | Panasonic HMTA1 Camcorder
Have installed HD Writer AE 1.0 for HDC on laptop running Vista. Works OK. Have tried to install on PC running Win 7 but won't load. Is there a way to upgrade software to run on a Windows 7...
If you have the CD with HD Writer AE, justfollow the steps below:
1. Go to the Administrator account and download the update software from: http://cnc.asp.hi-ho.ne.jp/cnc/global_cs/software/win7/Setup.exe
2. Insert the CD-ROM with the HD Writer AE1.0.
3. Double click the Setup.exe you just downloaded, and follow the procedure.
A free alternative to backup videos from camcorder to hard drive without HDWriter AE on Windows 7: Aunsoft Final Mate.
Jan 03, 2011 | Panasonic HDC-SD20 High Definition...
I can not download form HDC-SD20 use by HD writer
I have same problem. I have Panasonic HDC-TM20 video camera. It came with HDWriter ae 1.0 software. I have ACER alptop, running XP. Everything was running fine for months, but now I cannot transfer from the video camera to the hard disk on my computer. It attempts to do it, but then it just does nothing for ages. CPU usage shoots up high. When I kill the application, it does die, but process continues so I need to re-boot mt laptop before I can load it again. Is these any one out there who has resolved this issue?
Nov 12, 2009 | Panasonic HDC-SD20 High Definition...
try this converter: http://avs4you.com/AVS-Video-Converter.aspx?type=GoogleAdWordsSearch&gclid=CPzqs8yy6JcCFQEpGgodvyWzDA
Jul 22, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Problems using HD Writer 2.5E with Vista
I spoke to a technician at Panasonic. He said the problem is the 64bit Vista. It may run with the 32bit version, if gives trouble there is a patch update under Global Support/consumerproducts (digital AV window updates) at Panasonic web page. It will work with new Windows 7.
Feb 09, 2009 | Panasonic HDC-SD9 Flash Media Camcorder
Conversion from AVCHD to MPGEG with Panasonic HD WRITER
The video formats that your Panasonic HD-SD5 produces is AVCHD format, you you can choose an AVCHD video converter to help you to convert AVCHD to MPEG.
The most easiest and fastest video converter i ever used is Aunsoft MTS Converter which can hel you to convert MTS video files to almost any video format you need.
If your want to join your sapareted video files into one, this software can give you a hand due to its function of merjing video files into one.
http://www.aunsoft.com/mts-converter/
Aug 30, 2008 | Video Cameras
Problem with HD writer 2.0E
The reason for this error is that there is a conflict between HD Writer and other software on your computer. I was trying to find a solution for weeks before Panasonic advised me to remove other DVD burning software on my computer. I therefore removed Pinnacle and DVD decrypter (which I believe was causing the problem), reinstalled HD Writer and then everything worked fine. Note however that the DVD-RW discs I had tried to use before were corrupted and couldn't be reformatted and therefore once you have removed the other software and reinstalled HD Writer, start again with new DVD-RW discs. Good Luck.
Jul 23, 2008 | Panasonic HDC-SX5 DVD Camcorder
Computers & Internet Logo
222 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
