Question about Sanyo Projector Lamp for PLC-XU100, PLC-XU110
No electricity goes through my Plc-xu110. it was working perfectly until a current surge b/c someone turn-off the breaker abruptly. In that case what should I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 06, 2015
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
Electrical problem with FA561XF
Could be the breaker. Sometimes breakers just get old and will not hold when a power surge goes through it as when an electric motor first starts up. You have already replaced the compressor with a new one so I would check out the breaker situation. STAY with the same size breaker
Nov 24, 2013 | Smeg Refrigerators
No power reset button on bottom?
There is a power reset for this device. It's a tiny hole on the bottom in between the lamp access door and the CAUTION label. If your projector gets a surge of power, instead of blowing a fuse, it just trips a little breaker inside the device and all you need to do is push a paper clip (unplug your device first BTW) into this hole and it will reset the breaker. Hope this helps.
Nov 25, 2010 | Sanyo Projector Lamp for PLC-XU100,...
QUERO COMPRAR A LAMPADA PARA O PROJ. SANYO PLC XU 100 BARROSO 86-9981-2684
USD140,the Original lamp
have a nice day!
Aug 17, 2010 | Sanyo Projector Lamp for PLC-XU100,...
We had a power surge now when i plug my fridge in it blows my circuit breaker
The power surge might have damaged the wiring to the refrigerator. You can check this one with a megar. That is only if the circuit breaker blows off, ONLY when the unit is turned on. Else, the problem may be that current is flowing through the neutral. You can check it with a tester and if so, report it to the electricity board. Else, as a temporary measure, you can connect your unit, bypassing the circuit breaker. But in that case the circuit breaker will never blow off regarding any complaints to the unit and may result in a slight power wastage.
Jul 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do i install fedders a/c ?
the brand does not matter ,the process for instlling any window unit is the same only the sizes are different. And the power supply are different. Rule of thumb on power supply up to 12000 btu 120volt 20 amp dedicated electric circuit. over that requires 240volt circuit 30amp breaker dedicated line. As far as installation the window you chose to install the unit is MUST be within six feet of the electric outlet.Remove the casing from the main unit, I assume you have windows that you can raise up. put the leveling and side panel components on the casing, have someone help you. Place the casing in the window centered in the opening. lower the window until it is behind the top flange of the casing, screw the casing to the windo sill, lower the leveling screws until the unit is tilting toward the outside . insert the weatherstripping over the casing and lower the window as far as it will come down behind the casing flange. extend the side panels to the window casing and secure if necessary. Insert the main unit in the casing and push it all of the way in. make sure there is not any air leaks around casing or side panels. if you have done the electrical work or have had someone do the electrical work then plug the unit in, turn on the circuit breaker that is dedicated for that unit. read your startup directions and you are ready to go.
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Curcuit breaker pops
hello elanalex,
When your heater shuts off it trips your main breaker and that is usually associated with the interupt capacity of the breaker ( which means that while your heater is drawing current, if the thermostat says stop.. you are interupting that current demand abruptly and your getting a surge back to your breaker, You may be able to add a surge arrestor to that power feed to suppress that problem. You may also be able to repsecify your main breaker with one that has a higher interupt capacity.. Check with a local electrical supply house..explain the problem and they should be able to provide a hardware solution. Make sure you provide details on your circuit breaker brand so they can provide the proper solution.. GoodLuck
Regards,
Rick
Dec 04, 2008 | Dayton G73 Utility Heater
Sanyo  Projector Lamp for PLC-XU100, PLC-XU110 Logo
122 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
