Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
AC Compressor running outside but no air coming out of inside vents.
My Thermostat is set to cool and I can hear the compressor and fan running outside but nothing coming out of the vent inside my bedroom. All other vents through the main floor and upstairs work fine. My bedroom is controlled by a different thermostat.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Posted on Aug 25, 2008
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
I have a digital Honeywell thermostat that has a blinking snowflake. When the thermostat is on auto mode it does not turn on. When I turn the thermostat to fan I can feel and hear the air blowing out of...
If the thermostat has a blinking snowflake then it is in time delay mode which sometime can take between 5 to 7 minutes before it will turn the AC and Fan On......Then it will go to a solid snowflake.
When you turned it to fan On it starts the Fan right away..... After the snow flake has went to solid check to see if the fan is running and then look outside to see if the Fan Blade is turning on the AC..... The fan blade comes on the same time as the compressor does. Then with the fan running hold your hand above the air stream above the AC and if you can noticeablely feel warm to hot air comeing out the Top then the compressor is running also. If the outside unit is not running I would check to make sure the Main Breakers are turned ON.... After the AC has ran for a few minutes feel the copper lines that go into the house the smaller line should feel warm to hot and the bigger lines with insulation on it should feel cool to cold and sweating with beads of moisture on it..... That is a quick test to see if the unit is working properly.....If you have a Thermentor and can Check the Temperature of the Return Air and the Supply Air .. You should have about 20 Degree F Between the Supply and Return........ 75* Return - 55* Supply would Equal 20* TD Across the Coil......
That is about all you can do to check on your own....... If the compressor is not coming on or the lines are not the temperature difference then you will need to get professional help for your Air Conditioning System..... Goood Luck Hope this Helps.........
May 14, 2011 | Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Bryant model 594DNO24-E Air out of vents not cool, fan is not moving on AC unit.
I think you are talking about the outdoor unit so see if you can hear the compressor running. If it isn't running then set the thermostat so that the unit is not running and give the pressure time to come down.(15mins-30mins) Discharge pressure will build up if the fan isn't running and cause the compressor to shut down that's the reason for doing this. After this set the thermostat to call for a/c then see if the compressor is running. If it isn't first check your circuit breaker or disconnect or fuses. One of these should be located close to the outdoor unit. If you have power and it's not running then look at the contactor to see if it is pulled in. The contactor supplies both the fan and compressor. After that then check you capacitor. Some use a double capacitor that works the fan and the compressor. Let me know what you find
Jul 04, 2010 | Bryant Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Outside unit will not operate
Sounds like a bad fan motor. Inside fan runs, compressor runs. Outside fan. Are your contactors pulled in when thermostat set on cool? If not might be a contactor. If contactor not pulled in touch the top of it with the end of a screwdriver. If fan spins turn unit off a buy a contactor...
Tip: Always make sure power at disconnect is off
Jun 10, 2008 | Carrier 38CKC042 Air Conditioner
Ac problems
Hello from KOOLBREEZES, this is a simle problem and easy to fix. You have 2-lines going to / from your outside unit. a SMALL COPPER -line and a LARGE COPPER line with insulations. The fat line is suppose to have moisture on it wheres it,s not insulated which tells you you have enough refrigerant gas comming back to he compressor but if its dry you,re low on freon and need a charge or the outside condenser is dirty and not getting rid of enough heat!
Jun 02, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
319 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
