Question about Power Acoustik Car Audio & Video
The navigation on my radio keeps sayin no signal how do I make it work
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having problems! First we need to determine if you have a factory aftermarket navigation system If it is factory, there is not very many options for you the consumer to do yourself. If you have an aftermarket radio (store bought) then find where the antenna is located. Most of the newer antennas are about 1 inch by 1 inch square. If it is on your dashboard, it needs to be routed to the exterior of the vehicle. Navigation is done by "line of sight" with the satellite. If it is blocked by metal under the dash or the under the roof of the vehicle then that would be your problem. If your antenna is outside the car, then you may have a break in the line which would require replacement of the antenna. All that I have spoke of is if you have an aftermarket system. Each aftermarket system is gender specific, meaning if you have a JVC headunit, then you will have to go to a shop that carrys or can get JVC parts. Maybe this helped! Good luck with your venture!
20 year car audio/video installer
Bay Manager
Posted on Mar 14, 2011
The box and atenna is the one that came with the unit i try another antenna one same thing the small light inside comes on what else can i do is there a program to do or anything i can do
Posted on Oct 19, 2012
How do I get my navigation to work on my farenheit radio?
Has it ever worked? Have you checked the wiring at the back of the radio?
Sep 08, 2014 | Farenheit Car Audio & Video
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
KEEP ON GETTING SEARCHING FOR RADIO SIGNAL
The tomtom traffic system uses either a 'O2 (White SIM) or Vodaphone (RED SIM). Service fluctuates between good and bad.
Contact tomtom support and ask for a replacement SIM card
Tel : 08451610009
Nov 24, 2013 | Tomtom Xxl 540t 5" Widescreen Portable Gps...
Radio wont work
Signal not mainly for antenna problems. You must be an external antenna.welcome to hobd2.Help you solve the problem of car
Mar 27, 2013 | 1998 Lincoln Navigator
Raido fuse
  • Hi, I can help.
  • Please see my diagram for a visual as well.
  • #7 fuse - 7.5 Amp is the radio signal fuse.
  • #14 fuse - 10 Amp - is for the Navigation radio.
  • # 22 fuse - 10 Amp - Both radio delayed accessory feed and Navigation radio (EHAM) antenna amplifier..
  • # 4 fuse - 15 Amp - DVD player / navigation radio.
  • Be sure to check all of the fuses I have listed as any could be the one you need to replace.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 13, 2011 | 2004 Ford Expedition
I CAN'T GET CONNECTED TO MYSPACE FROM NETSCAPE NAVIGATOR. IT KEEP SAYIN I NEED TO UPLOAD ANOTHER SITE I BEEN USING WHICH IS MOZILLA FIRFOX. HOW DO I GET PASS THAT. I REALLY LIKE NETSCAPE.
if your myspace is still working through netscape navigator then no need to follow the message on your computer that needs to download Mozilla...Mozilla is just a alternative browser that can use as well if you want to visit some web :D
Nov 21, 2009 | Computers & Internet
My signal keeps sayin SOS and it tells me to insert sim card when
1.check the sim card if it is properly inserted.or try other sim card.
2.did you turn on your wifi?turn it on to have a signal from your network.
3.Is it unlock/openline already?
4.if the above mention is still not working its already a hardware problem.
Jul 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I cant get my p168 cect to work it keeps sayin emergency and loosing service
The phone goes into this mode when it doesn't pick up a signal from your cellular provider. Because at&t mostly uses lower fequencies that this phone was not designed to use.. the phone will pick up a signal from another provider in case you need to dial 911 or something. you may want to take your phone in for service or upgrade your phone
May 13, 2008 | Lands Phones
Car Audio & Video Logo
95 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
