Question about Car Audio & Video
Saw a post w/your reply about how to remove 2007-2009 Saturn Aura stereo. Description says to gently pry out the trim ring around the stereo and climate controls. I have a "Plastic Panel Tool", and tried to gently pry up that trim ring - it did not budge. In fact, it broke the plastic trim panel with only a slight amount of prying. It is astonishing to me what a mystery it is on how to remove a factory stereo from a late model Saturn AURA. *LOL*
    Sniper:
  • 50 Answers
Hello... sorry about hearing about your problem! Here is the correct procedure for removing your radio. (little late now eh??) First you need to remove the trim around the shift knob with the plastic removal tool. Then remove the panel with the storage pocket, and unplug the power outlet plug. Next remove the trim panel which goes across from the passenger side to the ignition switch and underneath/around the radio/climate controls. Note: you will need to unsnap the instrument cluster panel to allow trim panel to completely come out. After this you will remove the 6 (7mm) screws holding the radio/climate controls together. Then, viola! You have your radio out....(after unplugging it of course!) Hope this helped and good luck with your venture. Depending on the wiring harness adapter you have, you may have to run an ignition wire to power up your radio (the red wire).
20 year certified car audio installer
Posted on Mar 14, 2011
Testimonial: "Thank you, very much, for the quick reply. Panel is not broken, only the trim tool. I will try this procedure. I very much appreciate your help!"
  • roger_mukai Mar 14, 2011
    I see I mis-spoke slightly - trim ring was not broken - trim tool broke. I will attempt again following this procedure. Greatly appreciate your very timely reply.
    Very sincerely,
    Roger Mukai
  • Derl Maxwell
    Derl Maxwell Mar 14, 2011
    No problem!
Saturn aura remove dime light
Cover should pop off...
Nov 26, 2013 | 2008 Saturn Aura
How do I change the radio out in my 1994 dodge Sat
Disconnect the negative battery cable from the Dodge battery. The negative cable connects the battery to the frame of the vehicle. Use a Phillips-head screwdriver to loosen the cable'c clamp. Remove the clamp from the negative battery lead post.
Remove the dash trim panel that surrounds the stereo and climate control knobs, using a trim panel removal tool. Start at the bottom of the trim and work the tool around the perimeter until the panel is completely removed.
Remove the screws on either side of the Dodge stereo mounting bracket with a Phillips-head screwdriver.
Pull the stereo unit from the dash mounting bracket. Pull the stereo far enough to reach the wiring connections at the rear of the deck.
5
Disconnect the wire groups from the back of the factory stereo. There are four groups, for the antenna, power supply, speakers, and amplifier. Grab the groups by the plastic wire binders, not the wires themselves.
6
Reconnect the negative battery cable to operate the vehicle or any electrical components. Place the negative cable clamp around the negative lead. Use a Phillips-head screwdriver to tighten the clamp until the clamp cannot be moved around the lead by hand.
May 30, 2013 | Car Audio & Video
Where is the computer
The trim ring on the double din radio pops off with careful prying, then remove the 4 screws around the radio frame and ease it out. Disconnect the radio harness and antennae right behind where the stereo was is the ECU held in by 3 10 mm bolts.
Mar 08, 2012 | 1992 Eagle Talon
2008 saturn aura stereo not working
Well it is obvious that the radio has a failed circuit board and the noise (electrical) that it creates is triggering mute. You will need to remove the radio and send it in for repair to an authorized GM electronics repair center, If you click this LINK it will take you to a on line GM radio repair business, call them.
Feb 16, 2012 | 2008 Saturn Aura
How to remove and put the a new radio in a toyota highlander 2002
  • Disconnect the negative battery cable and ensure it doesn't contact any metal parts. Place the transmission into the "Drive" position and set the parking brake.
  • 2
    Remove the trim from around the stereo by prying at one of the bottom corners with your fingers. Apply pressure until the clips disengage and work your way up the trim. Once the trim is free from the dash set it safely aside.
  • 3
    Locate and remove the six 10mm bolts that hold the stereo in place. Pull the head unit out of the Toyota highlander dash and disconnect the wires from the back of the radio.
  • 4
    Connect the wiring harness adaptor to the original harness. Mount the new stereo into the Toyota radio mounting kit and secure it by following the manufacturer's instructions. Plug the wiring harness adaptor and antenna wire into the back of the new stereo.
  • 5
    Slide the entire stereo assembly into the dash and reconnect the battery cable. Turn the radio on and verify the speakers and controls are working on the new stereo. Secure the stereo in the dash with the six 10mm bolts and replace the trim ring around the radio.
  • Dec 07, 2010 | 2003 Toyota Highlander
    Need to remove stereo. how do i get that bad boy out.
    removee the battery terminals first so you dont short any wiring!
    pull knobs off the dials exposing the shafts which have nuts & washers on them
    Undo them & slide out the unit unplug wiring loom & antaenne etc from behind the unit!
    Cheers Rob
    Aug 16, 2009 | 1998 Toyota Camry
    How to replace remote passanger mirror on Saturn L-Series
    They have 2 white retainers on the back of the corner trim panel.They usually just pop off,gently pry from the top & it should come off.Sometime the retainers pull off the trim.If this happens just slide them back in before you re-install. Hope this helps
    May 13, 2009 | 2000 Saturn L-Series
    Ignition switch
    1. If equipped, disable the SIR system as outlined in . Disconnect the negative battery cable.
    2. Remove the ignition switch trim ring (bezel) by gently prying it out from the lock cylinder with a small suitable prytool.
    3. Remove the trim plate by gently prying around the edges with a small suitable prytool.
    4. Remove the tilt lever (if equipped) by pulling it firmly out from the steering column
    5. Snap off the upper steering column cover by gently prying between it and the bottom cover.
    6. Remove the lower steering column cover screws and lower the steering column cover.
    7. If necessary, remove the instrument panel cluster trim plate.
    8. Remove the two ignition switch bolts.
    9. Detach the two electrical connectors.
    10. Disconnect the ignition lock cable from the ignition switch.
    11. Remove the ignition switch from the vehicle.
    To install:
    1. Insert the key into the ignition switch cylinder and rotate it into the RUN position.
    2. Press the cylinder release plunger located at the four o'clock position on the ignition switch.
    3. Use the key in order to pull the cylinder from the ignition switch.
    4. Assemble the cylinder into the ignition switch.
    5. Verify the engagement and operation of the cylinder using the key.
    6. The remainder of installation is the reverse of the removal procedure.
    7. Good luck...
    Feb 27, 2009 | 1998 Oldsmobile Cutlass
    Removal of Radio
    With the key in position two, pull the gear selector to the lowest gear.
    With a bone too, or a screw driver, carefully pry up on the trim around the gear selector (the side closest to the center console trim, not the aluminum looking plastic directly around the selector).
    Underneath there are four clips that hold the aluminum looking trim to the plastic trim. Unclip those and carefully separate it. The clips should be one on each four corners.
    If you have the pen holder directly underneath the radio, that can be easily removed by gently prying on it to release it.
    Now there should be about a set of 2 (4 total) Torx 25 screws. Remove the two that hold the whole center console together.
    Pull the bottom section out towards you about half an inch and pry downward. The top of the assembly should have a slot that goes to the dash to hold the top section in.
    Put that assembly off to the side before you disconnect any connectors and put the vehicle in park.
    Once in park, take the key out. Most important or else you'll set codes and have to bring it to the dealership to have them erased.
    Now disconnect the connectors on the back.
    If you have the fiberoptics cables on there...you may need to get "bridges" for them so you can complete the fiberoptic circuit of the MOST system.
    Disassembly of the stereo assembly should be pretty straight forward after that. A few clips for the trim piece around the assembly, a few Torx screw removals and the stereo should pop right out.
    Any other questions...feel free to ask.
    Hope this helps.
    Jul 22, 2008 | 2001 Volvo S60
    Speedometer repair
    You can get the manual and trace the cable to the transmission.
    Jul 01, 2008 | 1995 Porsche 968
    Car Audio & Video Logo
    278 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
