Question about SanDisk Sansa E280 MP3 Player
No space for DB please delete more than 4 0mb
Hi.....
i'm in need of a small help...can any one fix my player's problem please..My player is SanDisk SansaE280 MP3 player....the problem is wat i wrote as the subject....
  • 1 more comment
  • rmuziotti Aug 14, 2008
    not enough space for music db please free 80mb
  • Anonymous Apr 26, 2009
    i need to delete 6 mb off my MD and deleting songs doesn't help at all.
  • Hektic1
    Hektic1 May 07, 2009
    Im having trouble with my SanDisk SansaE280 MP3 player each time i start it up, A message appears it says not enough space for music DB free 6mb, OK well.. I have no music on it, just a couple of pictures, when i try to put it on the computer it doesnt work, it only recharges i put it on MSC mode, it doesnt work.
Beware the following steps will completely reset your device to factory default and will delete any files you have placed on the device!
Be sure the device is OFF.
Slide the Hold switch atop the device to the right (orange showing).
Press and hold the REC button down while connecting to the PC. Keep the button held down until it pops up in the Windows Explorer( My computer) window, and the device says "welcome to Recovery Mode" on its screen.
A new icon will appear (in "my computer), labeled 16MB FORMAT.
Under NO circumstance, even if your PC "wants" you to, format this partition!! It will erase the firmware and bootloader of the device!
What we want to do is double-click the new icon labeled 16MB Format with your mouse to open its window, on a blank part of this new window right click and select New > Folder. Rename this new folder sansa.fmt and drop it into this 16MB partition.
The presence of a folder in there instructs the Sansa to perform a formatting operation.
Right click on the 16MB FORMAT partition logo, and select Eject. Then unplug. Your Sansa will format itself automatically.
Do not press any buttons on the device until formating is complete.
After formatting, then plug in again! Remember to flip the Hold switch back to OFF or you will get a key lock message, and the Sansa will shut down.
The Sansa should show up in the window.
This should restore normal USB communication. Then, you can establish an MTP connection.
Posted on Jun 22, 2009
  • 758 Answers
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Aug 19, 2008
I am getting an error "Not enough space for music DB. Free DB" How do I fix this
From the message it is very much clear the your device capacity is almost over. You need to delete some old songs or data. Then only you can copy the new one.
Aug 07, 2009 | SanDisk Sansa Clip MP3 Player
CANT FREE UP ANY SPACE ON MY SANDISK
The only thing to do for this error is goto My Computer/Computer and right click on the Sansa player, choose format.  Select Quick format.  It will delete all data but at least the player will work again.
Jan 24, 2009 | SanDisk Sansa Fuze MP3 Player
Not enough space for music DB. Please free 90MB
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Oct 29, 2008 | SanDisk Sansa Fuze MP3 Player
Sandisk c200
I would recommend that you format the device and then load everything back again..you can use your computer to format it..
Let me know if that doesnt work for you..
Thank you
Computerrep
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
MP3 player says Need to delete tracks
All you need to do is delete a few of your songs off, 2 or 3 should be enough.
Feb 21, 2008 | SanDisk Sansa c140 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Help me fix my Sansa c140
i had exactly the same problem and than i wrote the guys on www.sandisk.com they had my device replaced.
May 15, 2007 | SanDisk Sansa c140 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
452 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
