Question about GE WBSE2090A Top Load Washer
Hello, I have a GE WJRE5500G1WW cloths washer that is 3 years old. Water is leaking out of the plastic overflow tube that is attached to the outside of the tub. At first it was small but now it really wets the floor all around. I removed the front cover and watched it leak out of the bottom of the tube. I have tried different sizes of loads (super, large and small) but did not seem to make a difference. I have read the manual and am putting the right amount of soup so I know that's not it. I can watch the water level thru the tub and see that there is NO over sudsing. The water level is not even near the top rim. The tube is not cracked or damaged. I don't know what else to try. Note: It mostly leaks during the agitation cycle. Any reply will be greatly appreciated. Knee deep in clothes,
5 Suggested Answers
SOURCE: GE WJRR4170 washer comes out of overflow tube on super load
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Posted on Jul 12, 2009
Illeagle
  • 525 Answers
SOURCE: GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
mikedurland
  • 481 Answers
SOURCE: GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Posted on Jun 27, 2008
ginko
  • 19396 Answers
SOURCE: Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Posted on Sep 25, 2009
My washer will not stop filling. it will continue to fill and overflow. What do I do?
Hello there:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 03, 2010 | GE WJRR4170E Top Load Washer
My GEWBB2090G9WW clothes washer just installed and washer overflows - water fill does not shut off regardless of Small/Medium/Large load size selected.
HELLO THERE:
Sep 26, 2010 | Washing Machines
Leakng water. not every time. every 2 to 3 loads. also when it does leak the clothes are still very wet.
you nead to check your drain line.if you have a blockage the water will go out the overflow tube.
Dec 18, 2009 | GE Profile WPRE6100G Top Load Washer
The water keeps running and overflows the tub
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube (which you were blowing into) attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Oct 15, 2009 | GE WBSR3140DW Top Load Washer
I have a kenmore model 110 and it is overfilling the water doesn't stop and it overflows, flooding my basement.
Pull the top of your washer off, look on the tub and you will see a round plastic reservoir. You will see a plastic tube come out and to to the control panel. Make sure that hose is attached at the tub and the pressure sensor.
Sep 13, 2009 | Washing Machines
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
I have a 9 year old heavy duty top load washer that keeps overflowing no matter what water level it is on. I think it might need that part. If so how do I install it?
Water-inlet valve
Water-level switch
Apr 01, 2009 | Frigidaire Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
GE refrigerator Leaks in back when trying to use water dispenser
That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Ge washer overflowing/not rinsing or wringing well
if you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Mar 24, 2006 | GE WBSE3120B Top Load Washer
GE WBSE2090A Top Load Washer Logo
125 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
