Question about Whirlpool Washing Machines
How do I clean the pump of my Whirlpool AWOD 8927 machine please.
  • 6277 Answers
SOURCE: the clean filter lamp has
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 03, 2011
  • 333 Answers
SOURCE: the Whirlpool AW/OD 4545 front loader machine says clean pump
The back of the machine has an access door open it and at the bottom of the unit follow the hose from the barrel and the unit it connects to is your pump. I hope this helps.
Posted on Dec 10, 2008
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
  • 6277 Answers
SOURCE: Clean pump on a whirlpool
If your machine has a filter, which most models do have, it is the filter which probably requires cleaning but check the operation of the pump/motor at the same time ;-0)
John C
Posted on Sep 17, 2011
  • 6277 Answers
SOURCE: i have an AWOD 5556
(pre-typed 'cos it's a common problem!)
John C
Posted on Sep 19, 2011
Hi, I have a Whirlpool AWOD 5526, it is probably about 11 or 12 yars old (so I'm not hopeful!) and until now has always run without problems. I had a filter clean error code about 6-8 months ago which I...
f7=short circuit failure,ie =any number of small problems .But in this case I suspect a water flow problem,has the machine been moved and replaced ,,what im saying is the main water supply getting to the machine is a likely cause to show a f7 code,if not look at the water in as this is the likely problem.,Adrian....
Dec 13, 2014 | Whirlpool Washing Machines
Lost my user manual for my washing machine model Whirlpool 6100
You can down load an electronic copy at http://www.washingmachine-manual.com/whirlpool-awod-6100.html in a .pdf format. Save it to your computer if you do not require a full printed copy. Once saved, you can print select pages whenever needed.
Oct 14, 2014 | Washing Machines
Coming up f6
This was answered earlier please.
Mar 12, 2012 | Whirlpool Washing Machines
Clean pump on a whirlpool AWOD 5526
John C
Sep 17, 2011 | Whirlpool Washing Machines
How can I clean the pump in a Whirlpool AWG5070 washing machine?
Hi mariehazelwo,
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Whirlpool Washing Machines
I wish to download a Manual for the Whirlpool AWOD 7452 in English
whirlpool product litacture you can google and download from there
May 12, 2011 | Whirlpool Washing Machines
Error F05 on my awod as147 steam washing maching
F05 for Whirlpool washers decodes as 'NTC failure'. NTC stands for Negative Temperature Co-efficient and all that means is the water temperature sensor ;-0)
I have heard that occasionally it can be brought back to life by pouring in a few kettles of hot water into the washer, leaving for 10 minutes, spinning the water out and re-trying. If it doesn't work it means a service call. Sorry ;-0(
Good luck,
John C.
Mar 20, 2011 | Whirlpool Washing Machines
Model awod 4506 wont spin fills with water but wont spin will emty ok
Hey there buddy. Sounds like you're in a real pickle! First of all, don't panic!!! Same thing happened to my mate and he's fine now. Is it plugged in? Where do you live? I'll call over and fix it for you tomorrow.
Nov 02, 2010 | Whirlpool Washing Machines
Replace door seal on whirlpool model857037015500
Whirlpool AWOD 5726. How do you replace the door seal?
Jun 07, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
