Question about Fedders A7DH45B2A Dehumidifier
How to hook up a drain tube to the pan in the dehumidifer. Do I need to take out the float shutoff?
    Brigadier General:
  • 4,736 Answers
No, it is not necessary to remove the float shutoff. As water will be constantly draining from the unit, when the hose is connected.
Hope this helped you.
Posted on Mar 14, 2011
Float Switch
Contact there customer service at: www.sylvane.com 1-800-934-9194. you will need model number etc.
Feb 18, 2014 | Winix WDH751 Dehumidifier
"Check drain" light is on
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
Aug 06, 2011 | Therma-Stor Santa Fe Compact Dehumidifier...
I have a hamptom bay dehumidifer model # HB40-D i am looking for the tray that you attach a hose to drain
it should be in the same area where you pull the pan out to dump. There should be a hose hook up inside the space where the drain box is.
Apr 30, 2011 | Dehumidifiers
I've lost the manual. Can I hook a hose directly
yes you can, but you may have to drill it out to let the water out
Apr 10, 2010 | Maytag M7DH65B2A Dehumidifier
Unit does not turn on when the on-off button is pressed. No indicator lights come on. The line cord is good - I have 118 volts across the black and white wires inside the cabinet.
This unit has a 12 amp 125v glass tube fuse on the control board. Chances are you blew this fuse. This can happen if the unit is starved for air and ices up. you must take the front of this unit off to access the fuse of this control board.
Apr 08, 2010 | Haier HDN655E Dehumidifier
Do i need to disable the collection bucket to attach a drain line to my Matag dehumidifer M7DH45B2a? Or does it keep a full bucket and drain the overflow to the tubing drain?
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Aug 23, 2009 | Maytag M7DH45B2A Dehumidifier
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
Wont turn on
Check to see if the styrofoam float is in place correctly. Hopefully this fixes your problem. If the little plastic finger is broken on the float, then it will allways read full. At this point you could use the plastic tube that came with the owners manual to hook up a hose and then have it drain to a drain or try to super glue to finger back together. Here is a link to the tube that I was talking about.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-%60BMaytag+%60ADehumidifier-%3d%3db195i1013825&PartID=1013825
Jan 18, 2009 | Maytag M7DH65B2A Dehumidifier
Uggg, mine did not come with the drain hose. Any ideas?
I have the same model and bought a clear plastic hose at Home Depot, and drain it into a nearby bathtub. I don't have the size handy but just measure the diameter of the hose fitting, and make sure the hose has an inside diameter to match. Some stores sell hose by the foot; I bought a prepackaged roll.
Jun 26, 2008 | Maytag M7DH65B2A Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
130 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
