Question about Paragon 1015-00RS Indoor Multi Operation Timer
Need instruction for setting time of day - Paragon 1015-00RS Indoor Multi Operation Timer
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 15, 2011
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Jun 12, 2011 | Hardware & Accessories
How do I program the timer to turn on and off at specified times?
You need to program the timer so it turns on-off at specified times.
But first we need to identify your timer for sure.
Have a look at link below.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
If your timer does not show, then add a comment with description of timer.
I have extensive files on timers.
Intermatic DT300, GE 15091, and Woods 59203 are the same timer.
Here are instructions for Woods 59203:
Plug timer in until battery is recharged.
If display will not show, then timer battery needs to be plugged into outlet for 1 hour until internal battery is recharged, or timer is bad, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Once display shows, then unplug timer for programming.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
If instructions don't fit your timer, then add a comment with model number or full description and I'll post those instructions.
Also you can take advantage of Fixya phone service where expert speaks with you over the phone for a price.
Dec 21, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
Setting time day date in ESQ Aerodyne
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jul 26, 2010 | ESQ 07301132 Aerodyne watch
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
Programing of UTILITECH 0192773
All the information you need is in the instructions The problem is the instructions are printed so small and the way they are printed make them confusing. I will assume that you have the wiring correct. The timing goes like this: First press the time button The display will turn to the year. Press the + or - button to set the year press time. The display for the month begins flashing Press + or - to set the month. Press time , the day begins flashing Press + or - to set the day press time . The aera of the country flashes. Press + or - to correct aera press time. Programing: Press program This gets you in to the Sun up / sun set mode . You can change the times here by +or- . OR press program through this to program the daily time. Press program the display reads 12:00 not flashing.
Press + or - to set the day or days . The display is realy hard to see. You will need to look almost under the top baisel to read it . + or - throgh to the day or days you want . press time . The display starts to flash . Push + or - to the time you want to turn on. press program. You are now in the OFF mode for this event. Set the off mode as above and press program. Set as many of the 7 events as you need in the same maner. When you are finished press time for 2 to 3 sec. Be sure that the timer is in AUTO mode or nothing you have done will work.
May 19, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
VCR Co-pilot video programmer
Fortunately I've found the instructions. However for anyone needing to know how to set the time of day - here goes - along the top above the display there are 3 tiny recessed buttons marked day, hour, min. Using a pencil or other pointed implement press these buttons to set.
Oct 05, 2008 | Televison & Video
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Paragon 1015-00RS Indoor Multi Operation Timer Logo
206 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
