Question about GE JBP65 Electric Kitchen Range
Oven was used and then turned off but the oven heating element will not turn off. Need to know how to repair.
jsrock516
  • 5911 Answers
SOURCE: broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Posted on Feb 02, 2008
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
How do you get to it? On my stove there is no access panel
Posted on Mar 06, 2008
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My range ,GLES388DSA, lower oven element does not turn on.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 15, 2015 | Ovens
Magic Chef cgr3765adc, oven will not turn off. If the unit is plugged in the oven ignites and would continue heating unless disconnected from electricity.
follow this test and fix it. God bless you
Bake Element
If the oven won't turn on, check the bake element. The bake element is a black tube near the bottom of the oven about as thick as a pencil. When it is operating normally, the bake element will glow red hot. If the oven won't turn on the bake element may have burned out. It is often obvious to see where the bake element has shorted out because there will be a hole or break in the element. If the bake element has burnt out or shorted it should be replaced.
Oven Igniter
Even though the oven igniter may be glowing, it may be too weak to allow the gas valve to open. If the oven won't turn on and the oven igniter glows for more than 90 seconds without igniting the gas flame, the oven igniter should be replaced. This is the most common part that fails when the oven won't turn on.
Broil Element
If the oven won't turn on, check the broil element. The broil element is a black tube near the top of the oven about as thick as a pencil. When it is operating normally, the broil element will glow red hot. If the oven won't turn on the broil element may have burned out and caused something else to short out. It is often obvious to see where the broil element has burned out because there will be a hole in the element or blisters on the outside of the element. Test the broil element using an Ohm meter. If it has continuity it's OK. If not, it should be replaced.
Incoming Power Problem
Although not as common, if the oven won't turn on it is possible that the appliance is not receiving proper voltage. Electric ovens require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the oven won't turn on. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn on the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't turn on, first test the simpler components in the circuit. The oven control board usually can't be tested and will have to be replaced if it is defective.
Thermal Fuse
Although not as common, if the oven won't turn on the thermal fuse may have blown. The thermal fuse is designed to protect the appliance and help to prevent a fire. If the oven gets too hot, this fuse trips. The thermal fuse is not resettable and will have to be replaced. It can be checked for continuity. If it has continuity, it's OK. Not all ovens have a thermal fuse.
Relay Board
If the oven won't turn on and the appliance is equipped with an oven relay board, one of the relays on the board may have failed. Normally the oven relays are located on the main clock control board and not on a separate oven relay board. If the oven won't turn on it is more likely that the cause is one of the more common problems listed for the model. If the other, more common problems have been checked and Your oven has a relay board, it may need to be replaced. Oven relay boards are not repairable.
Oven Thermostat
If the oven won't turn on, the oven thermostat might be defective. Although this is not as common as other components, the oven thermostat sometimes fails completely and does not allow current to pass through. After checking other, more common components, consider replacing the oven thermostat.
Heat Selector Switch
If the oven won't turn on, be sure the heat selector switch is set to the right position. The heat selector switch completes the circuit to either send voltage to the bake or broil circuit. If the oven won't turn on, the heat selector switch might also be defective, although this is not very common. The heat selector switch is not repairable, if it is defective it will need to be replaced.
Oven Safety Valve
The oven safety valve works with the oven igniter to provide gas to the burner. If the oven won't turn on it is possible that the oven safety valve is defective. However, this is very rare. Most often, the oven igniter is too weak to allow the oven safety valve to open. If the oven won't turn on, check the igniter first.
Oven Valve and Pressure Regulator
If the gas oven won't turn on the oven valve and pressure regulator might be at fault. This is not common. Very often people misdiagnose a defective oven valve and pressure regulator when the oven won't turn on However, this is almost never the cause. Look at other, more common components before replacing these.
Nov 04, 2013 | Magic Chef Kitchen Ranges
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Oven won't heat up
Ok, this is a definite element malfunction. you can confirm this by using a multimeter and connecting the meter to the terminal points on the element. once connected, turn on the heating cycle and if you can register a reading and the element dosen't light or produce any heat, this will confirm element failure and you will need to replace it.
Please rate and god bless:)
Apr 20, 2009 | Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted.  I have experienced this problem before.  The board is not serviceable and (unfornately) you will have to replace it.  The board can run anywhere from $100 to $200 for a new one.  Slightly less for a refurbished one.  Prices will also vary depending on source.  This is a repair you can do yourself if you choose to do so.  If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you.  Let me know.  I hope this is helpful.
Oct 31, 2007 | Kenmore 95592 / 95594 / 95595 / 95599...
GE JBP65 Electric Kitchen Range Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
