Question about Toshiba Televison & Video
How do I change the time on the Nemio XG? - Toshiba Televison & Video
I have a Minolta XG-A camera, and i can take a picture but the shutter is stuck?
My shutter does that when there is low light, or just slow shutter speed. You could try changing those settings, otherwise, last time mine got stuck, I loosened a screw on the bottom right under the shutter release button and the shutter just snapped back into its place.
Jun 09, 2012 | Minolta XG-A 35mm SLR Camera
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
Should the timing belt be changed as preventative maintenance?
Yes, definately, 60,000 is the recommended replacement miles. Cost? Around 200 to 250.00
Oct 26, 2009 | 2002 Hyundai XG350
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
Sharp xg-e850u projector owners manual
I've searched all over...heh, I've got TONS of Sharp service manuals but *not* yours...I did find, however, the xg-e650 manuals on manualsparadise.com. Sharp units, a lot of times, are very similar in architecture, functions, parts, etc. For example, practically any Sharp remote will work on your projector...BTW, the lamp you need is a BQC-XGE850U/1 and sells for $292-389 dollars.http://reviews.cnet.com/peripheral-accessories/sharp-projector-lamp/4505-8309_7-31382143.html?tag=mncol;lst
Sep 08, 2009 | Sharp XG-E3500 Multimedia Projector
My projector
press the source select button. it may have just changes sources.
Mar 19, 2009 | Sharp XG-C55X Multimedia Projector
Setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Sep 03, 2008 | La Crosse XG-55 Wrist Watch
Televison & Video Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
