Question about LG Televison & Video
LG 26LC55 tv. multiscreennews page on pg1001 not obtainable.goes straight to dave channel followed by message due to a technical fault this service is not available.can this be fixed?
  • pymster Aug 15, 2008
    Just been on phone to LG customer services who assure me this is not a fault of the tv but one from the broadcaster.Would not budge from this and refused to accept any tv fault even though I told them your advice..What now?
  • 14 Answers
Yes it can be fixed , if you have the manual call the manufactuer and ask for the technical dept , if you dont know the manufactuer look on the back of the tv and there should be a sticker that says distributed by and then call 411 or 1 800 555 1212 good luck sincerely john
Posted on Aug 01, 2008
LG 26LC55 SCREEN WARM UP FAULT
What is the problem do you face with this device. Provide more details. http://electronicshelponline.blogspot.com/
Feb 10, 2017 | LG Televison & Video
My monitor comes on for 2 seconds and the goes blank. i get a dsub analog message
This is the technical fault i.e any IC damaged. better take it to the service center or any technician.
Aug 29, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
I have DR386D DVD Recorder and I cannt get it to tune in to HD Channels. The message I am getting is "HD Service not available" I am getting HD channels on my LG TV so I assume that the Antenna...
I wonder if this model is meant to receive HD channels in the first place. If it isn't, that is probably why you get that on-screen message. If it has a built in SD digital tuner, then it is not a HD digital tuner/DVD recorder; it would only be SD, hence the message.
It is possibly a limitation of the model, not a fault.
Mar 02, 2011 | LG Televison & Video
Tv LG 26LC55 takes about 10 mins for the picture to come in, sound comes in straight away. It's connected via Sky also to LG dvd/video combi via scart AV2/AV1. Have tried reconnected all leads even tested...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 14, 2017 | LG 42LC2D 42 in. LCD HDTV
All the bbc channels are coming up with a message saying due to technical faults unable to show programme please try again later. this has been like this since tuesday
You need to do a channel scan. I think your area has 'gone digital'. Refer to your manual on how to do a channel scan, or post your make and model and we'll get back to you.
Zahc
Mar 26, 2010 | Televison & Video
LG 37LT 75 faults Picture freezes everything locks only solution is to pull plug and then restart. Occasionally just get black screen whaen changing channels. Recordings failing due to "time setting error"...
Call out an LG engineer, there are software updates which control the operations of the TV, it would appear that you have an older version & need this to be updated.
Jan 08, 2010 | LG Televison & Video
LG RT-42PX10
everyone's lucky day!  follow this link closely!  it will work!  it worked for me on my gateway, which has LG boards.  trust me.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Jul 19, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
102 people viewed this question
Computer Repairing
Computer Repairing
