How do I change the time on a Lathem 1000e? - Office Equipment & Supplies
  • Anonymous Mar 13, 2014
    HOW DO I CHANGE TIME ON LATHEM 1500e?
    Problem Solver:
  • 12 Answers
To enter the program setting mode, you should plug the AC adapter into the AC outlet and remove the cover. Thereafter press the SELECT button once. Then the clock goes into the program mode showing the " " on the display positioned at the "TIME".
Press the SELECT button and position the " " mark at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.) I believe there is also a "CHANGE" and "SET" button used to navigate and alter the time.
Posted on Mar 15, 2011
Testimonial: "The time clock is now changed! Thank you so much!"
Why is the time not changing
is it plugged in? maybe the motor has gone out. maybe the a spring has come loose. lots of things can cause this. maybe the exhaust bearing needs lubed lol. try www.gatewaytime.com for service, parts, maintenance, and time clocks.
Aug 12, 2014 | Lathem Manual Clock Time Recorder - 2126
Need to get a manuel so can set up 7000E
If it is a Lathem brand, you can go to their website and they have the manuals for them on there. I found one for my 7500E. I think your model is very similar to mine. Here is a link for my manual. Please see if it helps you any.
http://www.lathem.com/media/92694/7500e%20manual2.pdf
Apr 07, 2011 | Lathem Time 7500E Calculating Recorder,...
Lathem 2126 lost 20min over the course of 2 months. Replaced motor...now loses 30 minutes over the course of 1 week?
The motor is going out or the feed pawls are worn out. Upgrade to a TCX-11, they automatically set for daylight savings. www.gatewaytime.com
Jan 18, 2011 | Lathem Manual Clock Time Recorder - 2126
HOW DO I CHANGE THE RIBBON IN THE LATHEM TIME RECORDER 5000E?
send it into Gateway Time Systems in Pittsburgh...they will replace the ribbon, clean and lube it, and make sure the program is up to date for you. they did a wonderfull job on my company's time clock and they barely charged anything. i found them @ www.shop.gatewaytime.com good luck :), Adam
Aug 10, 2010 | Lathem Time Lathem VIS6002 Ribbon...
I have a lathem 1000e and it will not print when the card is pushed in...it will work a couple times then, nothing...any ideas?
Dec 04, 2009 | Lathem Time Lathem VIS6002 Ribbon...
I am trying to set the companies time clock for daylight saving time. Thank you Betty
send it into Gateway Time Systems in Pittsburgh...they will replace theribbon, clean and lube it, and make sure the program is up to date foryou. they did a wonderfull job on my company's time clock and theybarely charged anything. i found them @ www.shop.gatewaytime.com  goodluck :), Adam
Nov 02, 2009 | Lathem Time Lathem VIS6002 Ribbon...
We use a lathem time clock model #pc50 and we cannot locate the manual. how can i download a manual for this machine?
First off, I did NOT have a lamp issue! All I needed was a product "manual" as I could not find the one the company used to have. Secondly, there is no problem to solve; if I would have had the manual, I could have hooked the device up myself.
Thank you for NOT helping!
Sep 14, 2009 | Lathem Time Office Equipment & Supplies
Replacement ribbon for a brother fax machine
yes it does mean that. send it into Gateway Time Systems in Pittsburgh...they will replace the ribbon, clean and lube it, and make sure the program is up to date for you. they did a wonderfull job on my company's time clock and they barely charged anything. i found them @ www.shop.gatewaytime.com good luck :), Adam
Jun 20, 2008 | Lathem Time Lathem VIS6002 Ribbon...
Lathemtime clock 2121 series
This site doesn't have much in the way of Lathem clocks or support. Go to http://support.lathem.com for assistance.
Nov 04, 2007 | Lathem Time Office Equipment & Supplies
1,083 people viewed this question
k24674
jasbo
jasbo
