Question about Alcatel Newbridge MainStreet 3600 Multiplexer
NewBridge 3600 Mainstreet
I cannot access my 3600 via SP1 or the DCE interface using the db9 serial cable I have used in the past. Does anyone know what the pinout and whether or not I need modem or null modem?
  • gpluhs Mar 30, 2009
    Hello
    I From Colombia Latin America.
    My question is:
    I have The Cable, but.... What software I need to use acces for this port (sp1) to NB3600?
    Thanks for your time.
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Posted on Aug 02, 2008
Reset 90-0667-05 to vt100
If you log on to SP1 using VT100 and you get garbage the port is properly set for CPSS and you will have to use a craft interface to log on talking CPSS to the node. The S1 switch on the control card is to reset the database on the node, but you can also use this to reset the SP1 port back to VT100...be very careful doing the following procedure as you can delete the database. Power down the node and press and hold in S1 then power up the node still pressing in S1, look at the the display it will after going trough it's start up process display a "0" ...release S1 and press S1 again....this will reset your SP1 to VT100 and you will be able to log on again. "0" reset SP1 and if it display a "1" and you carry on you will delete the database. As I warned you the "1" will delete the database, if for some reason you are stuck on "1" just power done the node without pressing S1 and it will restore as previous setting....good luck!!!
Sep 16, 2014 | Alcatel Newbridge MainStreet 3600...
After a reset 90-0667-01 Controller Database to default setting can not have access to administrate
If you reset the control card to a "0" the SP ports will default to 9600 VT100. Make sure that you connect on the back plain SP1. Reset with"0" will only reset the SP ports. Reset with "1" will default your database and all connections will be lost. Access will be Level-5, Password-mainstreet.
May 03, 2011 | Alcatel Newbridge MainStreet 3600...
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
CPSS CONNECTED TO SP1 OF DXX CHASSIS
this is just for to appear the node on NMS. so if you are having some problem with it you can change it but you will not see it on NMS.
Jul 07, 2009 | Alcatel Newbridge MainStreet 3600...
We have our all Nodes on our network . They are accessed by NMS at our HQ . But the problem is that When we locally want to access DXX Node via ANM , it is not accessed.Also DXX Nodes SP1 and SP2 are CPSS...
You don’t need to configure SP1 for CPSS, log on to the node via you NMS and change it to VT100, then log in using a hyper terminal session on you laptop. If the SP1 port is setup for CPSS you will have to install a dongle and you will need to set your ANM up for networking meaning that you will have to speak to the node via CPSS. The only time you need to communicate using CPSS on SP1 is when you want to backup the database.
Jun 12, 2009 | Alcatel Newbridge MainStreet 3600...
Can't access to alcatel 3600 node managment station from faceplat
SP1 is belong to VT100
VT100 RJ45 DB9 1 8 2 7 3 2 4 3 5 5 6 4 7 6 8 --
Jan 09, 2009 | Alcatel Newbridge MainStreet 3600...
Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
1,436 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Thomas Perkins
Thomas Perkins
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
