Question about Chapin Industrial 3.5 Gallon Viton Concrete Open Head Sprayer #1949
I have a Chapin Hand sprayer #1949 3 1/2 gal. I need to know how to get the pump apart to install a Industrial repair Kit #6-4627. Thank you. Don H.
3 Suggested Answers
jas247
  • 844 Answers
SOURCE: I e-mailed a question on a Chapin Hand Sprayer
Welcome to FixYa!
"I have a Chapin Hand sprayer #1949 3 1/2 gal. I need to know how to get the pump apart to install a Industrial repair Kit #6-4627."
TO UNLOCK PUMP:
Turn handle counterclockwise until 3-prong clamp is loose.
Then rotate clamp counterclockwise to stop and lift out.
Thank you for using FixYa.
Keep me posted.
Jas247
Posted on Mar 23, 2011
emissionwiz
  • 77169 Answers
You need to comment back on the email link you were sent. Do not start a new thread.
How do I assemble a Hudson eliminator 30151?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Chapin Home and Garden Premium Nozzle Kit...
Is there someplace to buy a whole rubber washer repair/rebuild kit for a Roundup 4gal BP sprayer? It's square and was built in 2005 unlike the rounded newer ones. thx joe
I've found buying one thats too big and cutting it to size and shape works best on my sprayer. You could go for a sheet of rubber and cut it all out with an exacto knife too.
May 13, 2014 | Roundup Garden
Lid does not seal---very loose
If sprayer doesnt seal against pressure, I suggest check cover gasket A (image 1). Check pump cylinder gasket B (image 2) and additionally, check the procedure if pump dont build pressure. on how to remoce pump cylinder on follow lines.
If pump doesnt build pressure... in most instances, failure of the pumo to build air pressure in the sprayer is due to dry or worm plunger cul leather. To work on cup leather, always remove plunger from pumo cylinder. Do not attempt to oil cup leather through breather hole in **** cap.
First, unthread pumo cap A (image 1). If cap is too tight, and if pumo will build even slight temporary pressure, pressurizing the tnak will make it easier to loosen cap. Once cap is lossened, release tank pressure. Hold pump cylinder by inserting hand through tank filler openning (image 2), and unscrew cap all the way. Pull plunger from cylinder, and remove cylinder from inside the tank.
Place a few drops of clea oil (not heavier than SAE 30) on leather, and massage into leather until it is soft. Replace plunger cup leather if damaged (image 3). to remove plunger leather assembly, use coin rather than screw driver in the slot of the plunger cup retainer. To reassemble, hold pump cylinder in tank openning, with squared edge of flange, at top of cylinder, toward tank wall.
Hope this helps to solve it.
Sep 17, 2011 | Chapin Industrial 3.5 Gallon Viton...
I was spaying and pumping up the pressure, when pump went slack. I would try and pump it up , but spray would just dribbvle out and was weak in pressure
Hi and welcome to Fix Ya, I am Kelly.
One of the seals has failed in the pump. i.e cut o-ring or a leather rolled out of place.
Go to this link.. http://www.chapinmfg.com/PartsAccessories.asp
Find your model number and on the far right of the page is the repair kit for your sprayer.
This is the 6-6180 repair kit:
http://www.chapinmfg.com/ShowParts.asp?PartNum=6-8180
This is the 6-1925 repair kit:
http://www.chapinmfg.com/ShowParts.asp?PartNum=6-1925
The repair kits above are examples only... find the kit that is for your sprayer and order it.
Once you find and replace the damaged seal it will work fine.
Thanks for choosing FixYa,
Kelly
May 16, 2011 | Chapin Garden
I e-mailed a question on a Chapin Hand Sprayer #1949 5 days ago and have not heard from anyone. Don
Welcome to FixYa!
TO UNLOCK PUMP:
Keep me posted.
Jas247
Mar 23, 2011 | Chapin Garden
I have a chaplin SureSpray, and it was given to me. On the bottle it says it is for pest control, fertilization, and weed control. It is a 1 gallon sprayer. The model # is20000#20010. 1G/3.8L. I just need...
Push the handle all the way down turn it counter clockwise and unscrew the pump handle and lid open it up put in your product and install if reverse order then Pump it to spray. Hope this helps if you need more help let me know. also sometimes they stick in this case run hot water over the cap area.
Dec 16, 2010 | Chapin 2001 Rb2000 Poly Sprayer 1 Gal
We have a 457 model hand sprayer. It wont pump to pressure , we think the end has come off the plunger. How do we pull the pump apart?
I recently ordered just the plug on the bottom of the shaft and it solved the problem. the company was really good about sending the plug right out for free at that. it worked and im back in business. just replaced it. no taking the pump apart.
The Pool Tech
Aug 07, 2010 | Solo 457 225 GAL DELUXE SPRAYER EA...
I have a 2 gal ortho heavy duty pump sprayer and I'm need a new nozzel. Where can I find replacement parts?
I guess a company called the Fountainhead Group makes a lot of different sprayers other companies. They have repair parts available on their site. I replaced the nozzle and installed fresh gaskets with a kit from Lowes and with info from this site; http://www.creativeworksforchildren.com/how-to-repair-ortho-roundup-garden-pump-sprayer.htm
Aug 03, 2010 | Garden
Sprayer Gun Problem
Before choosing a garden sprayer you must identify the problem. Some areas can be spot-treated with small amounts of pesticide, other areas (such as lawns or large gardens) need a larger capacity sprayer. Sprayer sizes vary greatly, from 1 quart to 4 gallons, so finding a model to fit various gardening needs will not be hard.
Aug 27, 2008 | Chapin Industrial 2 Gallon Viton...
Chapin Industrial 3.5 Gallon Viton Concrete Open Head Sprayer #1949 Logo
71 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
