Question about Proform Exercise & Fitness
I have a Proform 585 and the incline won't go up or down. When I push the button you can here the motor trying but nothing happens. Please help
    Problem Solver:
  • 5 Answers
As you are hearing the motor sound, It could be a problem as simple as the gearbox on the motor being jammed. We can remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn't run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Mar 15, 2011
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Pftl788071 incline
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
Apr 14, 2014 | Proform Exercise & Fitness
Won't incline
please RUN the software calibration for troubleshooting, Go to see the instruction manual or goes under the hood and follow the instruction guide.
see the diagram attached.
Nov 07, 2012 | Proform Exercise & Fitness
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
I have problemwith my PROform 585 treadmill and recently it is stop working ,as soon as I put the machine on it makes 3 bbeps noise and its stays like that for ever ,could not get it start it at all a
1) lUBE THE deck belt vs deck, this produce shut down for to protect the treadmill in your electronic system
2) lUBE The rollers bearing very well.
3) Measure the input voltage motor , if there are voltage, the motor need repair.
4)Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Jun 14, 2012 | Proform 585 CS Treadmill
My proform tl 585 is stuck on an incline. when i try to lower the incline, the button does nothing. the incline could still raise, but obviously i'd rather lower it than raise it more.
Take the cover off and inspect the wiring. Make sure all the wires from the incline motor are connected.
If all the wires are connected and everything looks OK, try the incline again.
There are only 3 wires on the incline motor, red, white and black. This machine does not rely on any electronics to operate the incline. We know the motor works, because it will go up..Likely the switch in the console is defective.
To lower the incline, reverse the black and red wires, that will make up go down and vice versa.. If that doesn't work, the motor is likely defective.
The incline motor is available, around $110. To order find the model number on the frame of the treadmill and call the service number found there. Have your model number ready (starts with "P").
The console is no longer available.
Feb 27, 2011 | Proform 585 CS Treadmill
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
Proform treadmill CR610 won't incline
Open the cover where the main motor is there
Tight the connector for Incline motor, and clean it with special contact cleaner for electronic.
2) See if there are wires loose,
3) Measure the 110 vac for forward and backward,
4) If there are , measure the l. switch or Capacitor for faulty and replace.
5) If there nOT 110VAC in forward or backward, replace the controller board motor.
6) If there are 110VAC, replace the Incline motor.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Proform 675 Crosstrainer Treadmill
My treadmill proform835QT fails to incline. What can I do?
Try to calibrate the incline: Hold down the stop and speed up buttons at the same time then insert the key. release the buttons the press the stop button and release then press the incline up button. the incline motor should go all the way up then all the way down with - - on the console. If the unit only moves just a and inch or so or the motor just hums , the incline sensor is faulty.
Jan 15, 2010 | Proform CrossTrainer Treadmill
Incline on treadmill is acting strange
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
May 12, 2009 | Proform XP 542S TREADMILL Drive Motor
Exercise & Fitness Logo
635 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
