Question about Sanyo Vpc-s1070w Digital Camera
"card protected " appears whenever i attempt a
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
If that doesn't work, try another card.
Posted on Mar 14, 2011
"Memory Card is write protected" so I can't take pictures.
remove memory card ... left or right side of memory you will see one little button slide the button down or up... this button is protected your memory..
May 28, 2013 | Nikon COOLPIX S6000 Digital Camera
Tip
Recover Deleted Photos From iPhone 6
It can be most aggravating when an important photograph is accidentally deleted. If you have an iPhone 6, then thankfully, there are a few options available for flv files recovery from this device. Remember, it is good practice to back-up your photographs every now and again by saving them onto an external storage device.
One of the first things to do in trying to retrieve deleted photos from an iPhone 6, is to open the Photos app on your smartphone. Once you have done that, do the following steps:
1.Select the "Albums" menu.
2.Select the album that you need and then select "Recently Deleted."
3.A list of all the recently deleted photos will appear.
4.Select the ones that you want and then tap on the "Recover" button to recover all the photographs that you selected.
5.All restored photographs will be sent to the album in which they were originally located.
If the photographs that were deleted were backed up in iTunes or iCloud, they can also be recovered. The important thing to remember is to have either iCloud or iTunes backup turned on at all times. If you are unsure how to do so, here's how:
1.Go to the "Settings" menu then select "iCloud."
2.Under "iCloud", select "Storage and Backup."
3.Then turn on the "iCloud Backup" feature on your iPhone 6.
4.As long as your iCloud backup is up-to-date, then all your photos can be easily restored to your iPhone 6 in case of accidental deletion.
Backing up your photographs to iTunes is equally as easy as backing them up to iCloud. However, once you connect your iPhone 6 to your computer or iPad, you need to ensure that iCloud is turned off; you can back-up to one or the other but not both apps at the same time.
If your photos have been deleted, then recovering your duplicate photos from iTunes backup or iCloud backup is not a problem. Simply launch iCloud or iTunes, right click on iPhone (the device in question), select "Summary", and then select either "Restore from iCloud Backup or "Restore from iTunes Backup." Once that is done, wait for "Restore in Progress" to complete and your device restarted.
When all else fails, a reliable data recovery software can be used to recover deleted photos from an iPhone 6. uFlysoft is one such user-friendly software that gets the job done quickly and thoroughly. The process is simple and takes these easy steps:
1.First, connect your iPhone 6 to your Mac computer then launch the uFlysoft data recovery software. You never want to launch a data recovery software directly from the smartphone from which you are trying to recover lost or deleted data.
2.Select the "Recover from iOS Device" option.
3.The software will then scan your device and present all the recovered photographs for you to preview.
4.The recovered photos can then be saved to any storage device or the computer itself.
RE: http://www.uflysoft.com/
on Feb 11, 2016 | Apple Genuine Original Iphone6 Earphones...
Mesage "unable to use card"
SD Memory Cards have a write-protect switch to prevent image
data from being deleted. By sliding the switch to the bottom of
the card, the data will be protected. images cannot be recorded
when the card is protected. If an attempt is made to record or
delete an image with the camera, the card-locked message will
appear on the monitor.
Sep 21, 2011 | Konica Minolta DiMAGE Z10 Digital Camera
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
I can't take pictures. A note that said " CARD SET- UP" is flashed. Then a power off or format appears if I click format and click yes there's a caution that all pictures will be erased. What...
There are indicators the data is corrupted on the memory card and the camera wants to format in an effort to correct the problem. If the photo's you have are important there is software available that might be able to retrieve some of your photographs. But if they are expendable then attempt the format in hopes it will correct the problem.
Feb 13, 2011 | Olympus FE-200 Digital Camera
Whenever I tried to make s shot it says "protected
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 22, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I have a panasonic DMC-FX07 camera Whenever i go in the rewind mode it reads " read error please check the card" and whenever i go to click a photograph or a movie it reads "memory full" I cannot...
i have the same massage .. but my problem is that i lost my original m.card and i tried to but another one ...and this massage appear even if i tried to connect it to my pc it cannot read it if you have any Aida plz help..
mustafa11darsh@live.com
Sep 24, 2010 | Panasonic Cameras
Light appears, but no image
just change the setting to outdoor. if you read your manual it will explain how. pg 27
Mar 08, 2009 | Canon PowerShot A420 Digital Camera
I have a Nikon D40. I wish my photographs to be numbered consecutively, 0 to whatever the numbering system goes up to (9999?), even when using a new card, without going into different files or...
You need to set "file number sequence" to "on" in the setup menu. However to get to this menu item you need to ensure that "CSM/setup menu" is set to "full", also in the setup menu.
The setup menu is the one marked with the spanner (wrench).
Jul 02, 2008 | Nikon Cameras
Sanyo Vpc-s1070w Digital Camera Logo
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
