My heater kicks on, I hear it but it is not blowing any hot air
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Mar 14, 2011
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
1996 buick centrey fuse box
Does the compressor kick in when you turn it on?(if not it could be the a/c switch or the power to it, the a/c clutch wire connection, the clutch itself, or it's low on freon) You should hear the clutch kick in when you turn the a/c on. Low freon will also cause the clutch to not kick in. Remove the low-pressure switch plug and jump it with a piece of electrical wire. If the clutch kicks in, you just need to add some freon. Put the plug back where it was after you remove the jumper wire.
Is the belt on and adjusted to the right tension? If the belt is loose it won't cool as good as it should.
Check the freon in the system with a gage. If it's low, add some to the right amount and see if it cools. If it is overcharged, it will blow hot air, too.
The heater control valve slider should be all the way to the left so hot water isn't allowed to circulate through the heater core which would also make it blow hot air out the a/c ducts.
Good luck, they can be a pain, but with careful, step by step troubleshooting it can be fixed. There is plenty of information about a/c online to help you out. Try googling in: auto ac troubleshooting tips for more info. garcuda
Sep 03, 2014 | 1996 Buick Century
Hayward 100 series not blowing out air
if new heater and wired 120 volt check wiring try to reverse sounds like not showing rectification if old unit bad flame sensor
Jul 11, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Heater blows hot air only
ac not kicking on check freeon
Sep 28, 2013 | Daewoo Leganza Cars & Trucks
My heater on my 2000 cdillac escalade will not blow hot air
The heater core may be plugged. After the vehicle is warmed up to operating temperature, feel both hoses (careful they may be hot) and see if they feel equally warm. If one is noticeably warmer than the other, your heater core is likely plugged.
Jan 01, 2018 | 2000 Cadillac Escalade
1992 Dodge Dakota 2wd 3.9L V6 Air conditioning/Heater dosent blow? when i turn the air or the heat on i can hear the compressor kick on but it dosen't blow cold or hot? any help would be appreciated
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Nov 29, 2011 | 1992 Dodge Dakota
Driver's side defroster and heater vents blow cold air but the passenger side blows hot. Both sides should blow hot The temp is set any temp and it still does the same thing. It is winter so I don't know...
The doors that open and close in the heater control unit are ran by motors. It sounds like a motor has quit in yours. When turning on the defrosters the motor closes the door to the heat for the floor
Jan 12, 2010 | 1995 Cadillac DeVille
My heater stoped blowing hot air.antifreeze level
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox and Pontiac Torrent,
Tech JK
Oct 13, 2009 | 2006 Chevrolet Equinox
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
