Question about Kodak i1220 Pass-Through Scanner
I just got the i1220 plus scanner, and I set up a few custom configurations to suit my scanning needs. However, when I started scanning, the program will start to save the file, but then a few seconds in it will display the message 'failed to format images'. And this only happens with my 'colour pdf' and 'black&white pdf' settings. The black&white document (OCR quality) setting works fine, though a bit slow to save. Are there any possible solutions to this?? Or some way of resetting all the configurations to factory default so I can start over??
mohanchennai
  • 490 Answers
SOURCE: Is kodak digital science 3520DP a sorting scanner
I dont think any scanner can do that. The output is raster image and you need to use specific software to 'read' the individual ID number. The location of the ID must be same in all the documents.
After scanning the documents, using additional software, the ID can be captured and files renamed. It can be sorted later.
S. Mohan, Chennai
Posted on May 27, 2008
SOURCE: Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Posted on Mar 18, 2009
  • 7 Answers
SOURCE: Kodak 3520D scanner Front Scan Mod gain issue
Lamp need to be replace and re-calibrate.
Posted on Jul 20, 2009
SOURCE: kodak I1220
Kodak i1210 the red led is flashing and no work
Posted on Mar 26, 2010
mohanchennai
  • 490 Answers
SOURCE: Image quality on scans from Kodak i1220- I've had
Check if the glass is scratched. If the scratches are more, you may need to change the glass. This happens over a period of time.
S. Mohan
Posted on Sep 03, 2010
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
I scanned one size of a page. Why I got the result is two pages including 1 page with content and one page is blank. How can I fix this?
Tell your scanning software to only scan the front of the page. The i1220 can scan both sides of the page with a single pass. That's what its doing (the blank page is the back of your scan).
Dec 09, 2010 | Kodak i1220 Pass-Through Scanner
Problems with Kodak i1220 Smart Touch software
Go into C:\programdata\ and remove the kds_kodak folder. It may ask you to skip files it can't delete. Just click skip for all of them (probably around 15 files). Then reboot your computer and you should be able to scan.
Jan 23, 2010 | Kodak i1220 Pass-Through Scanner
I1220 scanner jamming
test the scanner using the scan validation tool to see what errors there may be. also make sure that the length detection settings in the driver is correct as this may also cause a problem, contact the support centre if the issue is not resolved, they can do a replacement for you
Oct 28, 2009 | Kodak i1220 Pass-Through Scanner
Scanner wont scan
Be sure that you have the latest scanner drivers from HP, for your system and OS. Often an easy workaround is to use Microsoft Office Suite document imaging.
The ms program can be found in the tools folder of the suite...Plus is that is almost always works on most any scanner, the minus side is that it creates only a .tif or a .mdi file. To read those, you need to set your DEFAULT program settings to call the Microsoft MSP viewer, typically located C:\Program Files\Common Files\Microsoft shared\MODI\11.0.
HP has been working on solutions to this issue. Further, HP has LIVE, free support available online, try connect to chat.
Doc
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Kodak I1220
Jun 24, 2009 | Kodak i1220 Pass-Through Scanner
Kodak i1220 Pass-Through Scanner Logo
1,509 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
