Question about NetGear WGR614 Wireless Router
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
  • Norman Skinner
    Norman Skinner Mar 14, 2011
    I don't wanna talk to the OS on it, I wanna change the CFE so that I can change the whole works, but this router's set so that any flash has to have a certain checksum and signature or it won't take the flash, thus I need to jtag it. The serial interface is useless.
  • Norman Skinner
    Norman Skinner Jun 21, 2011
    That router requires 1 4 resistor pack and another single resistor to be added to the circuit before the jtag will work, and the jtag has to be soldered to specific pads on the board.
    I can't explain the process without pictures.
  • NetGear Master
  • 7,733 Answers
Once you've got a serial console attached you can access the CFE which is a bit like the bios of the WGT634U. Start up minicom and apply power to the router while holding Control C. You should see something like the following:
CFE version 1.0.34 for BCM95365R (32bit,SP,LE)
Build Date: Tue Feb 24 03:21:41 CST 2004 (root@jackylinux)
Copyright (C) 2000,2001,2002 Broadcom Corporation.
Add MAC client version(DNI).
Initializing Arena.
Initializing Devices.
et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller
CPU type 0x29007: 200MHz
Total memory: 0x2000000 bytes (32MB)
Total memory used by CFE: 0x81BB1280 - 0x82000000 (4517248)
Initialized Data: 0x81BB1280 - 0x81BB3E90 (11280)
BSS Area: 0x81BB3E90 - 0x81BB45D0 (1856)
Local Heap: 0x81BB45D0 - 0x81FB45D0 (4194304)
Stack Area: 0x81FB45D0 - 0x81FB65D0 (8192)
Text (code) segment: 0x81FB65E0 - 0x81FFFFB0 (301520)
Boot area (physical): 0x01B70000 - 0x01BB0000
Relocation Factor: I:E23B65E0 - D:01BB0280
configure vlans
*********************** VLAN Driver initial ********************
Process LAN port(2-5) vlan Architecture...
SUCCESS: trying to create VLAN 0 for switch
SUCCESS: trying to add LAN port
Process WAN port(2-5) vlan Architecture...
SUCCESS: trying to add WAN port
SUCCESS: enable ports success
configure vlans...done
Automatic startup canceled via Ctrl-C
CFE>
Now you can get a listing of the available commands by typing "help". If you want to boot a kernel from a tftp server do the following:
CFE> ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;
CFE> boot -z -elf -tftp 192.168.1.10:vmlinux.gz
Or you can automate the process by setting STARTUP using:
CFE> setenv -p STARTUP "ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;boot -z -elf -tftp 192.168.1.10:vmlinux.gz;boot -elf flash0.os:"
The router will now try and retrieve a kernel image called vmlinux.gz using tftp from 192.168.1.10. If this fails it will go ahead and boot the kernel on the flash. The is quite handy as in conjuction with a NFS root, it means you can do all your development without modifing the original firmware.
Posted on Mar 14, 2011
Using Netgear WGT624 as wireless repeater for Motorola SBG6580
The best way and easiest way to do this is go to DD-WRT.com and download their firmware ,they have great wiki forum with extremely easy to follow instructions,if you prefer not to use their firmware it also has step by step instruction with full color pages to walk you through it.
Jul 26, 2013 | NetGear WGR614 Wireless Router
Can a netgear router be used as a repeater?
Yes it can ,if you are open to third party software it is quite simple using DD-wrt software ,they have great how to do step by step solutions or you can just view their wiki .
Dec 25, 2011 | NetGear WGR614 54Mbps Wireless Router...
WN3000RP-how to join network
Here is the owners manual. Starting on Page 16 it gives you details on how to set it up for a network. I do see many reviews online with people stating the extender does not work as advertised.
If you continue to have problems, you can utilize a $40 router and install DD-WRT or Tomato to make a $40 router a $400 router!
DD-WRT Website: http://www.dd-wrt.com/site/indexTomato Website: http://www.polarcloud.com/tomatoStep-by-Step from Lifehacker.com!
Dec 08, 2011 | NetGear Computers & Internet
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
Lost instruction
Lost instruction - NetGear
Nov 05, 2009 | NetGear WGR614 Wireless Router
Internet content filtering through my router
It depends on the Router & Firmware.  BUT it definitely can be done and VERY nicely using the DD-WRT Open Source firmware on a multitude of Router brands & models.
Feb 16, 2009 | NetGear WGR614 Wireless Router
WGR614 v6 will not connect through LAN????
Did you call NETGEAR already? Maybe your WEP was changed. If you can't fix this try http://technicalsupport.blog.friendster.com
Feb 12, 2009 | NetGear WGR614 Wireless Router
Have you fix you problem router and xbox live
you can? well i have a linksys wrt54g version 3.0 and i recently did a firmware upgrade from hyper wrt back to the original software and it completely screwed it up im unable to reload the new firmware dd-wrt thru tftp or any other method aside from a jtag cable and i dont have one any ideas? the tftp seems like it would work i can ping the router and get a responce but when i try ftp it tells me the router isnt responding
Nov 14, 2008 | Linksys WRT300N Wireless Router
NetGear WGR614 Wireless Router Logo
292 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
