Question about MSI K8MM-V Motherboard
Audio device not detected - MSI K8MM-V Motherboard
  • MSI Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 14, 2011
    President:
  • 2,246 Answers
Install audio driver
just insert motherboard cd driver then chose to install audio driver
Audio driver
What operating system did you use? Is it windows xp, if it is. Try installing the service pack 3. This will detect all the hardware that has not been detected.
Jan 25, 2013 | Acer Aspire One Netbook 8.9" Notebook
No audio nor device detected , i'm using windows xp sp3, no issues in device manager,what are my options. contact me at slickguy_33@yahoo.com thanks
Re-seat the sound card, or test with a different card if you can. Double check device manger with view hidden devices in safe mode.
Sep 20, 2012 | Microsoft Windows XP Professional for PC
The volume won't work anymore, it says the audio device supported by this application is not detected, the application will exit. was working grand yesterday
it,s saying the audio Device used by this Application ( Program )
Is not detected.
The problem most likely is with the program i.e media-Player, Cyberlink Power DVD Et,c.
uninstall and re-install your Audio/Music Application.
Also check the devices/Drivers are not corrupt or not installed.
Mike @ Compurepair,
Nov 05, 2009 | Dell Inspiron 6400 Notebook
"no audio device installed"
First check the device manager from the control panel. Check and see if there is a audio device detected and if it is a problem device.If the device has a problem try removing the audio software and then remove the audio device.then re-boot the computer and windows should detect the hardware and begin installing drivers. Make sure you have the updated drivers from Dell downloaded and the updated software. If it does not detect the hardware after re-boot you can try adding hardware manually in the control panel and have it auto detect any new hardware. If these thins do not work the audio card or built in audio may have stopped working. You can buy a basic PCI audio car for fairly cheap to install on your computer if you cannot get the audio to work.
Sep 05, 2009 | Dell Computers & Internet
Installation of audio driver
Check your device manager and see if the audio card is detected by the system. Usually if the drivers aren't installed, it will say audio controller with a yellow question mark or a yellow exclamation mark. If not detected, reseat your audio card if possible.
Thanks!
Aug 26, 2008 | Computers & Internet
I lost My Sound Card CD and i want to download the same cd via the Internet how can i do it.
Aug 12, 2008 | Creative Labs Sound Blaster Live! 5.1...
Audio On Computer
restart the computer so that the o/s can detect the audio device ,if after restarting it didnt work then check the status of your audio driver from the device manager if not detected reinstall if this didnt work then you know the spk is bad and needs replacement
Jul 16, 2008 | Computers & Internet
Asus a7s333 motherboard SiS745: onboard audio device not detected
1.) Check Device Manager for any "unknown" drivers, marked with a yellow exclamation point. If you find one that doesn't seem to belong to any of your other devices- you have your onboard. however, you may need to install the drivers for it.
2.) Check your BIOS. Some onboard cards have the ability to be enabled/disabled there.
Other than that, you could be looking at a dead card. All I can suggest if that's the case, to buy a new PCI soundcard to replace it.
May 29, 2008 | ASUS A7S333 Motherboard
MSI K8MM-V Motherboard Logo
184 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
