Question about HP Photosmart C7250 All-In-One Thermal Printer
I have a C7250 all in one. I am trying to scan pictures to my computer and the instruction manual says to press the scan menu and then scroll down to scan to comuter. The scan to computer is not an option on my C7250
  • HP Master
  • 1,591 Answers
You will need to transfer that option to the front panel menu through the solution center then.
darnit, it's been a while and I couldn't find my solution center emulator so here goes anyways.
Launch the solution center
near the bottom right there should be settings or something like that near a symbol of a wrench.
go into scanner settings or printer advanced settings (I think, it's been a long time)
Somewhere in there you're going to find front panel menu settings, and you have to drag Scan to computer from the list of available menu items to the front panel menu items.
Conversely, in the solution center, you can simply scan to the computer directly from the main menu there, or in almost any graphics software you can use the SCAN, Acquire, or Place Object functions (whichever your software has) to scan directly to the application.
Posted on Mar 14, 2011
  • HP Master
  • 3,606 Answers
You have to download and install the full feature package
for your windows system to make the scanner work on your pc.
When you have downloaded and installed the software
click on Hp solution center and select scanner options.
Down load it here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3382185&
Remember to select the system you are running 32 or 64 bit.
Hope this was helpfull.
Dect 1735. Led keeps flasing.No messages.Battey full
press menu button
select answering set up
scroll down to global set up
press menu
scroll down to VMWI
press menu select yes
press menu
then press exit save the instructions as it happens often with NBN
Nov 24, 2017 | Computers & Internet
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
Photosmart C7250 All-in-One. Copier, fax and printer work. But I cannot find my scanner icon where it was on my previous computer.
Were you able to install the correct driver for your OS? Usually the scanner application can be found in the list of Programs >> HP Photosmar C7250. If what you are referring to is the icon on your System Tray (lower right corner), you can always add an icon there by right clicking the blank space in your system tray and choose properties. On the taskbar tab, click on Customize, look for the icon for your scanner, click for the behavior and from the drop down button, choose "Always show".
Try to scan also by pressing the scan button in your printer and press start to initiate a scan.
Jan 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
I was trying to download the sansa media converter so could put pictures on my sansa e260 and im getting an eror installing iKernal.exe(0xa00) not sure how to continue
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
"the waste ink absorber is almost full"
Although the instructions posted here are for a different model, the procedure is almost the same for all ink printers. (I used it to fix my HP printer.)
Even if you can't get the ink pads out, you can try to dry them with paper towels.
Important: DO WEAR GLOVES!!! Put plastic bags around your work space. The ink IS evil and will not come off of anything it gets on.
The first time I did it without and it took forever to get my hands clean again.
Feb 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Scanning
Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
Scan to File 1 Place a photo or photos face down on the scanner glass.
2 Press Scan to display the Scan menu.
3 Press �� or �� to select Photo.
4 Press �� until Scan To is selected.
5 Press �� or �� to select File.
6 Press Start.
The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
You can change the folder where you want these saved. Just go to tools in your printer window.
Hope this helps- Happy scanning!
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Finepix a610 fuji -howdo i retrieve pictures from internal memory
The other answer doesn't work. I tried it. Okay, this is straight from the manual AND I tried it and it worked:
Press Play/playback to view pics.
Press Menu. Under playback menu, scroll down to COPY. Hit OK. Press OK for or scroll to & then hit OK for "Internal Memory -> Card" and press OK. Press Frame or All Frames. Press OK. Done! :)
God Bless. John 3:16
Nov 02, 2008 | Cameras
I do not know how to get pictures from internal memory to my computer.
Aug 22, 2008 | Cameras
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
HP Photosmart C7250 All-In-One Thermal Printer Logo
185 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
