Question about GE ZIS420NR Side by Side Refrigerator
Freezer freezes at top but not at bottom
Model ZIS42 GE Monogram. The freezer works fine at the top,for all the shelves, and the door. But it does not freeze anything in the baskets at the bottom of the compartment. All that food is cold but does not freeze. Setting is already on 7, doesn't seem to make a difference no matter how high it is turned up.
  • 481 Answers
  1. first make sure the fan is coming on in the freezer. if it is not working then the fan motor may be bad or obstructed.
  2. then Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 01, 2008
My fridge is cold on the bottom shelves but hot on the top shelve and freezer is not cold enough to freeze
ge has had alot of problems with the computer boards but this sounds like the evap fan isn't working,i need you to answer a few questions for me,first when you open the freezer door do you hear the fan blowing?also from the bottom up remove the second draw or food bin and put your hand on the back wall inside the freezer and tell me if there's like snow or frost on the wall,if so you have a defrost problem,one more thing check the model number,you'll find it in the fridge side,up on the right hand wall near the ceiling
Sep 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Freezer freezing ......top not cold
Verify the fridge "flap" which could be stuck closed. To do this remove the shelves and then remove screws holding the center panel (3 screws for a bottom freezer). At the bottom you will find a connector which can be unclipped so you can take the panel out completely from the fridge. See if the flap is closed if it is then that could be the problem. It may need to be replaced. Good luck.
May 10, 2009 | GE GBS18HBR Bottom Freezer Refrigerator
Bottom Door Shelves and Vegetable Crispers Freezing up
I just had a similar problem, and the bottoms of both sides were cold but the top shelves were warm. I found that the condenser fan, the fan right above the cooling coils was not working. This fan circulates the cold air and if it's not working it can't move the cold air to the top or over to the refrigerator side. Open the freezer door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. You will need to take out the back cover over the coils, the ice maker tray and auger motor if you have one and some other parts. Play around with the plug where it goes into the side wall, if you can get the fan to come on and off, it's most likely a bad fan motor....about $55 to replace. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Jan 12, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Monogram 42 built in freezing at top, just cold at bottom, not freezing
the next thing i would check on is the coils. make sure they are clean and the air around them is not obstructed and the condenser fan is running.  i am kinda scratching my head on this one because the freezer is working good on the upper shelves but not the bottom; even though heat rises. oh well, we will figure it out.
also if you have a thermometer that would be great. it would help to know the actual  temperature of the freezer, refrigerator and compressor/ coils. the best time to test the temperatures is in the morning when the doors have been shut all night.
  • as far as your questions
  • the compressor could be getting weak, but i always eliminate all other possibilities before suspecting the most expensive problem.
  • if it is a freon leak, then the refrigerator would progressively get worse and completely quit cooling within a day or so.
btw, make sure the lights are going out inside the bottom of the freezer when you **** the door.
Aug 03, 2008 | Refrigerators
Refrigerator warm, freezer too cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
GE ZIS420NR Side by Side Refrigerator Logo
166 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
