Question about Denon Audio Players & Recorders
I have the 1911 and Martin Logan Motion 10 speakers. Why do I have to turn the volume up so hi to get sound?
    Master:
  • 403 Answers
Are the ohms on the speakers and the receiver rated the same, if not theres the problem
Posted on Mar 14, 2011
I have a Martin Logan Abyss subwoofer. It has a volume control that when touched explodes the volume. How do I fix this?
Actually the most likely answer is that the volume control knob (potentiometer ) needs cleaning internally or replacing
Aug 16, 2017 | The Audio Players & Recorders
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
The Service Department
30 Unquowa Hill St
Bridgeport CT 06604
203-331-0671
Steven@theservicedepartmentct.com
www.theservicedepartmentct.com
Nov 14, 2014 | Krell Audio Players & Recorders
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
The internal speakers/sound have quit working. I can hear the sound if I put my ear right next to the speakers but it does not respond to volume control or nay other controls in "settings". Any Ideas?
Maybe the sppeaker is faulty or the output audio amplifier IC is faulty.
You must remove and check first the speakers , if Ok then check for main voltage tot he IC, if not check power supply, If yes then the IC can be faulty.
You can easily use an audio signal to test and confirm
Sep 23, 2010 | Polaroid 1911-TLXB 19 in. LCD TV
I own a used Martin Logan Dynamo (older series) and just today found out there is no sound coming out/no led light (at the back) either. I opened up the back and saw the 110V power is getting in but no...
Did you get the sub fixed? I know someone with the same problem - won't turn on, fuse is fine. May be due to different underlying problem, but wondered if you discovered what it was and if you got it fixed.
Mike
Aug 28, 2010 | Dynamo MartinLogan Subwoofer Speaker
Loudspeaker Repair or Buy New Replacement?
I have tried the repair thing before. They can be repaired the only problem is they dont seem to hold up as good or for long. I found it better just to replace speekers with new ones
Oct 23, 2008 | Cerwin Vega LS-15 Speaker
Volume programming
Not possible without disabling the speaker.
Jun 20, 2008 | Motorola Radio Communications
102 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
