Question about Health & Beauty
Gives a reading of 140. Should be about 235#.. Is the reading metric? Installed new batteries.
  • 11,800 Answers
That depends entirely on the exact model of your unit and from which country you purchased it . But since 140C = 284F it might be that the temperature is rendered in Celsius - in that case it' too high since 235F = 113C.
Posted on Mar 14, 2011
My dodge journey 2015 change to miles from km I would like to change it back
Hey, all you need to do is change your settings from imperial to metric or metric to imperial.
Your owners manual will have the exact steps on how to perform that, be sure to give that a good read if you haven't yet about 15 minutes and you'll learn a whole lot of cool features you might not have known about your car yet.
Nov 07, 2017 | Dodge Cars & Trucks
Where is the alternator on a 2003 chrysler concord and how do you change it what tools do i need
FIRST TURN OFF RADIO THEN DISCONNECT NEGATIVE BATTERY CABLE.IF YOU HAVE 2.7L ENGINE YOU HAVE TO REMOVE LOWER PLASTIC SPLASH SHIELD, REMOVE TRANSMISSION COOLER AND POSITION IT ASIDE.LOWER RADIATOR CROSSMEMBER SUPPORT, LOOSEN DONT REMOVE,ADJUSTING T BOLT AND THE PIVOT BOLT LOOSEN BELT ADJUSTING BOLT, REMOVE DRIVE. REMOVE ALTERNATOR FIELD CIRCUIT PLUG. REMOVE ALTERNATOR BATTERY PLUS TERMINAL NUT AND WIRE REMOVE.PIVOT BOLT SPACER CAREFUL DONT DROP LOSE SPACER. THEN REMOVE ALTERNATOR. YOU NEED BELT TENSION GAUGE TORQUE ADJUSTING T BOLT UNTIL TENSION GAUGE READS 120 LBS USED BELT NEW BELT 180 - 200 LBS. YOU NEED ALL BASIC MECHANIC TOOL SET WITH METRIC SOCKETS METRIC OPEN BOX END WRENCHES.SIZE WRENCH RANGE 5MM UP TO 19MM NEED ADJUSTABLE PLIERS NEED SCREW DRIVERS LIKE FLAT HEAD AND PHILLIPS. YOU NEED TORQUE WRENCH. FOR THE PIVOT BOLT NEED TORQUE TO 40 FT LBS. THE 8MM MOUNTING BOLT TO 30 FT LBS. 10MM BOLT TO 40 FT LBS.
Sep 08, 2011 | 2000 Chrysler Concorde
Need to change the alternator on a 2001 sunfire,2.4 engine,how do i do that?
Things You'll Need:
  • Battery terminal wrench
  • Serpentine belt removal tool
  • 3/8-inch ratchet
  • 3/8-inch metric socket set
  1. Turn off the engine and place the transmission in park (automatic) or first gear (manual). Engage the parking brake and open the hood. Disconnect the negative cable from the battery terminal using the battery terminal wrench.
  2. Remove the serpentine belt by inserting the end of the serpentine belt tool into the square hole on the belt tensioner and rotating the removal tool clockwise. Unplug the alternator's electrical connector. Remove the bolt holding the positive voltage cable to the alternator using a 3/8-inch ratchet and a metric socket. Remove the positive voltage cable from the alternator.
  3. Remove the alternator bracket bolts using a metric socket connected to a 3/8-inch ratchet. Remove the alternator from the car. Place the new alternator in the mounting brackets and reinstall the mounting bolts using a 3/8-inch ratchet connected to a metric socket.
  4. Reinstall the positive voltage cable on the alternator and tighten the retaining nut using a 3/8-inch ratchet and a metric socket. Plug in the alternator's electrical connector. Compress the serpentine belt tensioner using the serpentine belt tool. Reinstall the serpentine belt according to the belt-routing diagram located under the hood.
  5. Reconnect the negative cable to the battery using the battery terminal wrench. Start the engine and verify that the alternator works.
Oct 29, 2010 | 2001 Pontiac Sunfire
What are the torque specs for belt tensioner
There no real specs for the tensioner. The bolt should be tight and the unit as a whole should be squared to the engine. If it is in anyway tilted, th eunit is coming apart and will need to be replaced. One bolt holds this unit in place. It should have adequate tension to keep the belt taunt against all the pullies. If you are dealing with a constant squeel issue, locate the writing and you should be able to read it like holding a book in your hand. If it is upside down to you, reinstall. this will take care of the squeeling 9 times out of 10. The tensioners for replacement run about $50 - $75.
Oct 23, 2010 | 2005 GMC Sierra
2006 pontiac g6 radio locked after i installed a new battery.how do i get rid of that
You need to go to the dealer. They can read the computer and give you the code. Last I knew, about $75.00
May 12, 2010 | 2006 Pontiac G6
The message center on my 2006 f150 is being displayed in metric how can i change it to english
Select this function from the
SETUP menu for the current units
to be displayed. DISPLAY WILL READ: UNITS
<ENG>METRIC
2. Press the RESET control to
change from English to Metric
Jan 27, 2010 | 2006 Ford F-150
Acer Aspire 5050 I bought a new battery . My laptop works fine on Ac power but when I installed the battery it shuts off immediately
I apologize that I am having a hard time following the thread as to what you have tried and so forth. I will assume the following:
1. You have an old battery that does not hold a charge but the laptop does run with this battery installed, from AC or from AC w/no battery installed.
2. You have installed the new battery (with the laptop off) and it does not run from the battery or when plugged in.
3. You have tried charging the new battery 4-6 hours.
4. You are using the original charger or one that is fully rated for the laptop - I think this needs a 90W.
New question: does the charge light come on?
If the above are all true then there are 2 possible problems:
1. Bad (shorted) battery - this is possible, although unlikely, fro a new battery.
2. Power connection on the motherboard is faulty. The center pin may be loose, thus not giving full power to the system to charge the battery and run the laptop at the same time. This should be "overcome" by charging the battery w/system off. OR, the connector is like a headphone jack in that when you plug in, the primary connection is opened but on this series of laptop I have seen this fail.
Try powering up with the battery in and adapter plugged into the laptop but not to the wall.
Let me know what you discover. Reply w/my name so I know which thread to read.
Jon
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
Belt tensioner 1998 Saturn SC2
Battery keeps going down, new battery last three months?Also screaming when started, had new belt installed and it started that.
Oct 18, 2008 | 1993 Saturn SC2
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
