Question about Husqvarna Garden
I have a Husqvarna 61, it starts fine and will cut wood happily for the first five minutes of use, but then it looses power and stalls. It will start again fine, but then cuts out again soon after. I've checked the air filter, checked the spark plug and changed the fuel but still no joy. Any ideas of what I can try next? Many thanks Sam
  • Husqvarna Master
  • 2,239 Answers
Start withe the inexpensive stuff first, pull the fuel hose out of the tank and change the filter on the end, by your discription it could also be an electrical issue, the early 61 had a two peice system, an electronic block to the left of the flywheel, and a coil at the right, if you have this system check the where the yellow two wires connect under the head of a self tapping screw under the coil, if the connection is ok it may well be a case of replacing the electronic box. The later 61 has a single peice ignition system, this may be breaking down when it gets hot, and need replacing.
Let me know how it goes, and if you need help with part numbers etc.
Posted on Mar 14, 2011
My husqvarna 365 special stalled out yesterday while cutting a tree , it started back up after sitting for 10 minutes , now it won't start at all . It's getting fuel but not starting .
Check you have a spark, check the compression psi and check fuel is getting into the cylinder. Then reply with more info please
May 18, 2016 | Husqvarna Garden
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
I have a Husqvarna Z4217 was cutting and blades started making a rattling noise so I cut it off checking the blades the one on the right is loose but when I try to tighten it the pulley turns the blade...
You can use a block of wood and I even locked mine with a pair of vice grips or if there is room a pipe wrench. It would help to take it completely off and squirt some oil on the threads and start over then when you sharpen the blades they will be easy to take off later. I would sharpen the blades before you do this as well.
Mar 17, 2015 | Husqvarna Garden
Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Loss of power; Rancher 55
HI. FRIST OFF THOSE SAWS ONLY WORK GOOD AT HIGH RPM.NOW I ALWAYS SET MY HIGH SPEED AT 3/4 TURN AND THE SAME FOR THE LOW. WHEN YOU START IT UP, FIND A PICE OF WOOD THAT IS A BIG PICE OF WOOD THAN YOU SHOULD BE ABLE TO SET IT UP. IF THAT DOSEN'T WORK GET BACK TO ME THERE ARE OTHER THINGS YOU CAN CHECK. THANKS JIMBO
Aug 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 350 screammmmms
H carburetor adjustment might be too lean--try turning CCW 1/8 Turn or so--engine should 4-stroke at speed with no load and immediately smooth-out with light load (cutting wood). Any vacuum leak would cause no/hard starting. It is normal for the engine to "scream" at speed--are the chain and bar being properly oiled? Use hearing protectors.
Jun 08, 2009 | Husqvarna Chain Saw 20" Bar
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Husqvana 61 chainsaw starts but cuts out after a few seconds
Are you pumping the primer till it's full of fuel? The fuel pump diaphram is only strong enough to keep things flowing after you have pumped it up. you will need to prime it up again if you run it out of fuel or if it sits any length of time
Mar 25, 2009 | Husqvarna Chain Saw 20" Bar
Bad Clutch??
Hi
Before other checking change the spring of the clutch(2).
best regards savumihai71
Feb 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
235 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
