Question about Belling 335 Electric Kitchen Range
I have removed the door on my belling 335wh oven and cannot refit the door, what should i do?
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
My belling 335wh oven or back hotplate doesnt work
The thermal fuse in the back of the oven is faulty. If you have a multimeter, select OHMS and check across both terminals of the fuse will show it to be open-circuit. You can compare with the grill thermal fuse. Change the oven thermal fuse and it should be ok. While you're checking this, may be you can solve my problem. both your oven elements will have one terminal connecte together by a grey wire then both earths connected by green/yellow wire, the remaining terminal hopefully has a yellow wire, can you tell me where the other end is connected to.
Jun 28, 2012 | Belling 335 Electric Kitchen Range
Reinstalling oven door which was removed by overseas movers
Have a look on You Tube, there are a number of videos that demonstrate how oven doors can be removed, it normally revolves around latching the hinge. Refitting is a reversal of the process.
The following video shows a number of different methods to remove and refit the oven door
Hopefully, one of the methods shown in the video will help you.
Jun 15, 2012 | Hotpoint Ovens
Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Dec 06, 2011 | Fisher and Paykel Ovens
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
My belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Belling 335 Electric Kitchen Range Logo
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
