Question about SAMTRON 55V 15" CRT Monitor
9to15pin vga moniter pin circute - SAMTRON 55V 15" CRT Monitor
  • 3,606 Answers
There is an adapter for sale that a hole lot easyer:
Hope thiss was helpfull.
Posted on Mar 14, 2011
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Screen color problem
Some circutes are not working properley so please go to your nearest service center otherwise call to the moniter service center
Jun 23, 2008 | Computers & Internet
My e machine computer
Check the VGA cable - it's usually a blue head, and connects to your PC. Sometimes one or more pins can get bent out of position and cause the monitor to not function.
To fix this problem, simply grab a set of needlenose pliers and reset the pin to its proper upright position. This will take some muscle energy, but does not need to be perfect, as the pin will straighten out fully once re-plugged in.
Jan 06, 2008 | E-Machines eMachines Desktop PC
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Pinkish Color on Monitor
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Jun 09, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
SAMTRON 55V 15" CRT Monitor Logo
189 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
