Question about Inverter Power ,1500W, WESTWARD, 1YAY9
We havve a Westward 1YAY9 1500W inverter which has worked well for a long time. Now it often stops working after 5 minutes and after it has been shut off for a time, will start again. The pump we run is drawing its normal 6.5 amps.
    Sergeant:
  • 257 Answers
It is overheating. A good test for this is to use a soft gel pack that can be put in the freezer. Use and old towel to wrap the ice pack once and set it on top of the inverter for about 20 minutes. Then use the pump. If it runs longer, the inverter is going bad, and will cost more to repair than to replace. Check all wiring for green corrosion as this can also cause overheating, but the fact that you have the same power draw leads me to a bad inverter. 6.5 amps is pushing a 1500 watt pretty hard, try stepping up to a 2000-3000w Westward.
Posted on Mar 14, 2011
How do I set time on Westward 6JG70 stopwatch?
Go to date and time screen. Hold Mode button for 5 seconds or until seconds figure on stopwatch starts blinking. Then use upper right button to choose seconds, minutes, hours, year, or date. Use upper left button to set the blinking figure. Press Mode when done.
Oct 09, 2014 | Westward 6JG70 Digital Stopwatch,...
Air compressor
isn't one but the owners manual might have some simple trouble shooting info in the back
Nov 13, 2013 | Westward Air Tools & Compressors
Dead panasonic nnp294 microwave
You problem will be with either the Magnetron or the Inverter. The mags are around 100.00 the inverters are much more. Sometimes it is BOTH parts. There is a signal that goes from the main board through the inverter and back to the main "PC" board, if something doesnt report properly, or the signal doesnt get through, it shuts itself off as a safety feature. Sorry, yes, costly repair. Probably time to get a new one. I reccomend one without the inverter. I find them a pricey pain in the bottom. Good Luck.
Oct 09, 2017 | Microwave Ovens
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 7 seconds, it has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
The oven stops partway into the set time, and doesn't heat.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other. Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these. You can find an authorized Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Panasonic Microwave Ovens
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Panasonic Model NN T964SF inverter microwave runs for less than 5 seconds and shuts off. Power control function does not work either. Pressing power control a number overrides cook time with power...
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 02, 2008 | Microwave Ovens
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Inverter Power ,1500W, WESTWARD, 1YAY9 Logo
143 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Clint Millett
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
