Question about NEC Laptop Battery 108V Liion 3600 mAh
Power cord is plugged in but laptop battery is not charge in
  • kaushikjgec Mar 14, 2011
    but my battery is taking charge in other dell1525 laptop,so battery is out of service you cant say Mr. bebeserban.
  • 81 Answers
The battery is out of service and you must change it if the laptop goes with power supply.
Posted on Mar 14, 2011
  • bebeserban Mar 14, 2011
    Why didn't tell so? In this case it's possible power plug in to be interrupted or power supply adaptor not works. I don't want to think that is a malfunction on motherboard....!
  • kaushikjgec Mar 15, 2011
    Thanks bebeserban for your reply.
    but what I have to do? Should I buy new power plug? or my power cord pin is damaged! At present I'm using my laptop just as Desktop PC, My battery is not getting charge and I too dont want my battery's capacity comes down to zero level (current battery capacity is showing 71%). Each day battery capacity is coming down to 1% though I am taking utmost care and shutting my system down if power goes due to some reason.
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
Evertek e500 not chargijng
Does the laptop work with just the power cord plugged in? If so, that means your power cord is ok and if your battery is not taking a charge then the battery is dead. Batteries only have a useful life, then they have to be replaced.
If you laptop is having issues staying on or booting up with the power cord then either your power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. Either one will cause the battery not to charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
With power cord plugged in and without power cord plugged in the pc will not turn on
remove the battery, plug-in power cord then power on. your battery may be completely drain and your power adapter can't give enough supply to power up your laptop and charge the battery at same time. if doing so power on your laptop, charge your battery for about 12 hours without turning the power of your laptop
Nov 03, 2009 | ASUS EEEPC901-GP010X Netbook
NEC Laptop Battery 108V Liion 3600 mAh Logo
64 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
